ᐅ Why doesn’t my IKEA Metod countertop fit properly?
Created on: 21 Mar 2015 10:13
Navin
Hello everyone, I recently ordered and installed an IKEA Metod countertop, but it doesn’t quite fit the designated kitchen space. Specifically, on one side the countertop appears to overlap by about 1 cm (0.4 inches), while on the opposite side there is a gap of approximately 1.5 cm (0.6 inches). I measured the countertop multiple times before installation and also had the kitchen cabinets checked; they all seem to be correctly installed. The cabinets were assembled exactly according to IKEA’s instructions, and it is a 3 m (10 feet) long kitchen run with base cabinets that are 60 cm (24 inches) deep. My question is: what could cause the countertop not to fit properly and such dimensional discrepancies to occur? I look forward to your assessments and suggestions for resolving this. Thank you!
Annedeo
21 Mar 2015 16:26
I agree with FABIAN_DEO, especially regarding the advice about the overhang on the sides.
FABIAN_DEO schrieb:
IKEA gives a guideline for the Metod countertops stating that an overhang of up to 2 cm (0.8 inches) is allowed at the front edge — however, this is intended more as a visual finish to the floor and not for the sides.
A side overhang of one centimeter (0.4 inches) already seems too much to me; in general, only a few millimeters (fractions of an inch) should be allowed on the sides. If the overhang doesn’t bother you, you can leave it as is. Otherwise, you can partially adjust the material using a carbide saw blade or a sanding tool. However, I recommend being careful to avoid damaging the surface.
Another option would be to shorten the countertop slightly—if you are confident with DIY—or to order a custom-cut countertop directly from IKEA. Especially with uneven walls, a custom cut is often the best solution.
chentan
22 Mar 2015 09:14
Good morning Navin, I would like to take the opportunity to specifically address the installation process with the panel holders. You mentioned that you used the standard Metod panel holders. These holders are designed to secure the countertop at only two points per cabinet: front and back. This allows the countertop to shift or warp slightly in other areas — which could explain the overhang.
Additionally, attention to the rounding of the countertop edges is important: some countertops have rounded edges that are meant to fit snugly against the cabinets – if this is not the case, a gap can occur.
Important: Since the wall is uneven, you need to either align the cabinets using shims to create space between the wall or plan for a shadow gap. The countertop can be shifted slightly on the panel holders but not enough for one side to have a 1cm (0.4 inch) overhang.
My recommendation: Lift the countertop, temporarily install the holders loosely, and see how the countertop positions itself. Then gradually tighten the holders, continuously checking if everything is aligned. If you have a laser tool, verify that the countertop edge aligns flush with the front edge of the cabinets.
milau42
22 Mar 2015 11:37
You could also check whether the countertop might be warped. Sometimes during transport or storage, the panel can bend slightly due to moisture or tension.
A 1 cm (0.4 inch) overhang on the side sounds like a more serious issue. The panel is probably not completely straight, or it was not mounted evenly.
Measure the overhang continuously in several places using a spirit level and a ruler. This way, you can identify if there is a spot with a particularly large deviation.
Fredlo
22 Mar 2015 13:15
Wow, that sounds really frustrating with the countertop! But keep your chin up, you’ll definitely manage it! 🙂
I had a similar situation once: my countertop had a small gap on the wall side, which bothered me at first, but after adjusting the cabinets a bit and sealing it with silicone, it was hardly noticeable.
Don’t stress, with some calm and patience, it will surely turn out great – your kitchen will look fantastic!
Wishing you continued success!
V
vinli
23 Mar 2015 08:24
In summary:
- The countertop should overhang at the front by a maximum of 2 cm (1 inch), and only minimally on the sides. A side overhang of more than 1 cm (0.4 inches) usually indicates an installation or measurement issue.
- Wall irregularities must be compensated for by adjusting the cabinets.
- The countertop must be level and free of warping.
- Using the mounting brackets to precisely shift the countertop can help; however, the brackets offer only limited adjustability.
If you cannot correct the overhang by shifting the countertop, the only options are reworking the countertop or purchasing a properly fitted replacement.
Navin
23 Mar 2015 12:47
Thank you all for your input; it has been very helpful! Today, I removed the countertop again and slightly adjusted the cabinets on the wall side using shims, so the cabinets are now almost perfectly aligned. After that, I was able to bring the countertop closer to the wall, reducing the overhang from about 1 cm (0.4 inches) to just a few millimeters.
I have now accepted that the wall is uneven and will fill the remaining gap with a narrow silicone joint. Additionally, I plan to slightly refine the edge on the side to improve the appearance.
Thanks again for your support — without your advice, I wouldn’t have approached this so systematically and precisely.
