ᐅ Retrofitting IKEA Metod Soft-Close Drawers for Increased Kitchen Comfort
Created on: 5 Mar 2020 09:12
gijsbuHello everyone,
I’m planning to retrofit my existing IKEA Metod kitchen drawers with a soft-close feature to significantly improve comfort. Currently, the drawers do not have any damping, which can sometimes make them sound loud and feel imprecise with frequent use.
I’m especially interested in:
- Which soft-close kits are compatible with Metod drawers?
- Are there any specific installation tips I should be aware of to ensure optimal function?
- Has anyone had experience with how durable and reliable these retrofit solutions really are?
- Are there any recommendations on how to properly adjust the drawers so they close smoothly without sticking?
I appreciate any detailed responses or specific product recommendations. Thanks in advance!
Hello gijsbu,
I can provide you with a step-by-step guide on how to retrofit your IKEA Metod drawers with a soft-close function.
1. Compatible Soft-Close Kits: Make sure that the dampers or soft-close adapters are specifically designed for Metod or at least compatible with IKEA. Many third-party suppliers offer kits that can be easily attached to the existing mechanisms.
2. Installation Instructions: First, carefully remove the drawer front panel to access the side rails. Typically, soft-close dampers are either snapped in or fixed with screws. It is important to position them precisely according to the instructions so the drawer closes smoothly.
3. Adjustment: After installation, fully pull out and push in the drawer to test the resistance. Any sticking can usually be resolved by fine-tuning the screws on the rails.
4. Durability: Soft-close mechanisms are generally made of durable plastic and metal, so they withstand frequent use. It is important to install them gently to avoid damaging any parts.
Summary: Purchase a soft-close set made specifically for Metod, follow the installation guide carefully, and adjust as needed afterwards.
If you want specific product recommendations, I’d be happy to provide some names.
I really like your idea, gijsbu! I also had issues with loudly banging kitchen drawers, especially when you’re in a hurry in the morning.
I think that’s very important too, because you don’t want to install just any damper that might not work properly and just ruin the experience.
I’m actually curious whether the conversion can be done without much tooling, or if it’s better to be well prepared—especially if you don’t have much experience. If anyone has tips, that would be great to know!
JAFUHAU schrieb:
I am actually curious whether the renovation can be done without much use of toolsThat is a very valid question. Usually, you only need a Phillips screwdriver and possibly a small flathead screwdriver to remove or attach the front panels. Some sets are indeed assembled without screws, avoiding drilling or the stress of drilling.
Tip: Make sure to empty the drawers completely before starting, as handling them otherwise can become quite tricky.
You generally don’t need tools like a drill or sandpaper unless you want to adjust particularly old drawers with irregular holes.
I always wonder if the whole soft-close hype is really necessary. Sure, it sounds convenient, but you can also get used to gently closing drawers yourself.
Besides:
- Spare parts cost money
- Installation takes effort
Maybe it’s better to consider investing in a completely new kitchen with integrated soft-close technology instead? Retrofitting somehow feels like a quick fix.
Besides:
