ᐅ Is there a guide on how to adjust Ikea Metod drawers yourself?
Created on: 9 Aug 2022 08:37
Diteo
Diteo
9 Aug 2022 08:37
Is there a guide or a reliable method to adjust Ikea Metod drawers yourself? Specifically, I want to know how to set the drawers so that they run as straight as possible without sticking or wobbling. I have the impression that many drawers in the system slightly catch or don’t close completely flush after assembly. Are there simple steps for this, perhaps some kind of calibration that can be done by yourself? I would like to work through it systematically, but I don’t know if Ikea has special adjustment screws, hidden catches, or tricks that I might have missed.
chenValeri
9 Aug 2022 08:51
With Ikea Metod drawers, you can easily release the clips on the back to adjust the front panel. There are also small rotary adjusters at the bottom to change the height. When inserting the drawer, make sure it clicks properly onto the runners.
barle
9 Aug 2022 09:03
The drawers have screws on both sides for fine adjustment, allowing you to align the front in height and tilt. Just try a few small turns and then check how the drawer closes.
Diteo
9 Aug 2022 09:26
chenValeri schrieb:
When inserting the drawer, make sure it clicks properly into the runners.
Could you please explain the correct way to insert it in more detail? I suspect that errors often happen here, causing the drawer not to sit properly on the slides. Is there a technique or an indicator that tells me everything is correctly locked in place?
chenValeri
9 Aug 2022 09:35
Diteo schrieb:
Is there a technique or signal that tells me everything is properly locked in place?
The drawer should click audibly when it locks onto the runners. Gently push it in until the resistance disappears and you hear a click. That means it is correctly installed.
Tevin
9 Aug 2022 10:07
I can explain this in a bit more detail. The Ikea Metod drawers have clips at the back that snap onto the metal runners. When installing, make sure to insert the drawer straight and not at an angle, otherwise it won’t fully slide onto the rails.
For adjustment:
- On the back of the drawer front, there are usually small screws that allow you to adjust the front vertically and horizontally.
- Additionally, you can adjust the height using the small knobs underneath the drawer if it’s not aligned properly.
- If the drawer sticks, check that all runners are clean and nothing is obstructing the track.
If the drawer sticks, a slight adjustment of the front panel may also help so it doesn’t rub against the frame edge.
