ᐅ How do I determine the optimal height for Ikea Metod wall cabinets?
Created on: 23 Jun 2020 09:13
Norbertreo
Norbertreo
23 Jun 2020 09:13
Hello everyone, I am currently planning my new kitchen with Ikea Metod wall cabinets and am focusing on how to determine the optimal height for these cabinets. Specifically, I am interested in which factors are crucial when positioning the wall cabinets above the countertop to ensure ergonomic use while also providing enough storage space without overwhelming the room’s atmosphere. Are there any standard measurements or rules of thumb that I can use as guidelines? I have varying heights of the countertops installed below, and I plan to work frequently at the stove and sink in the kitchen, so the optimal height for easy reach is also important to me. I look forward to hearing about any experiences, tips, or recommendations shared here in the forum. Thanks in advance!
gekira
23 Jun 2020 09:47
For planning the optimal height of Ikea Metod wall cabinets, I recommend first considering the users’ height. The cabinets should be installed so that the countertop is fully accessible and the bottom of the cabinets is approximately 50 to 60 cm (20 to 24 inches) above the countertop. This is a common spacing that provides enough storage space without compromising usability. Additionally, it is important to consider whether appliances such as a stove or sink are located beneath the wall cabinets, as these require more clearance for comfortable use. Ikea’s own kitchen planning guidelines recommend about 60 cm (24 inches) of space, which is ergonomically suitable for most users.
Kyler10
23 Jun 2020 10:15
Additional to the points mentioned: Besides the distance between the countertop and the bottom edge of the cabinet, the plinth (toe kick) of the kitchen cabinets is also relevant if the countertop is higher or lower. In Metod kitchens, the standard countertop thickness is approximately 2.8 cm (1.1 inches). Wall cabinets are usually installed so that their bottom edges are positioned around 140 to 145 cm (55 to 57 inches) above the floor. This applies to an average room height and user size. If there are very tall or very short users in the kitchen, this measurement should be adjusted to avoid ergonomic strain.
tutan
23 Jun 2020 11:22
I installed my Metod wall cabinets so that I can easily place my large coffee mug on the countertop next to the sink without having to bend my head – that’s about 55 cm (22 inches) of clearance for me. I also noticed that if the cabinets are installed too low, the kitchen quickly feels cramped. So it’s better to leave a bit more space! 😉 Also: If you cook with a lot of steam, slightly higher cabinets help protect the wood from damage.
LAGUDO
23 Jun 2020 13:07
A distance of 50 to 60 cm (20 to 24 inches) between the countertop and the bottom of the cabinets is optimal. This ensures enough room for comfortable movement. For the installation height, a measurement of 140 to 145 cm (55 to 57 inches) from the floor is generally recommended.
Liduta
23 Jun 2020 15:36
Here is a structured suggestion on how to plan the optimal height:
- Step 1: Measure your height and determine the usual work surface height (countertop height)
- Step 2: Calculate the distance between the countertop and the bottom of the wall cabinets, ideally 50 to 60 cm (20 to 24 inches) – this allows comfortable use of kitchen tools and space for larger appliances
- Step 3: Consider special features such as range hoods, adjustable wall cabinets, or lighting under the upper cabinets
- Step 4: Plan the total height from the floor: countertop height plus cabinet clearance plus cabinet height
A common mistake I often see is choosing a height that is too low – this quickly creates a cramped work area. The optimal solution is always a generous height with good visibility and easy reach.
