ᐅ Dishwasher front panels
Created on: 26 Mar 2014 11:26
Sektionschef
Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
9
999kaktus
19 Feb 2017 10:12
This is what we did after reading in this forum that the dishwasher should be placed at the very back at the bottom. Placing it at the front doesn’t quite work because the floor (in an older building) is not completely level, causing the machine to stand unevenly and wobble. We really tried it, but with an 80cm (31 inch) plinth height, the door is about one centimeter (0.4 inches) short of fully opening.
Nörgli
19 Feb 2017 10:21
Would it be possible to raise the rest of the row by this 1cm (0.4 inches), or is everything already fully loaded? (If it even hangs on the rail, that would, of course, be a much bigger effort...)
9
999kaktus
19 Feb 2017 13:29
Yes, unfortunately everything is already installed and firmly screwed to the wall, including the wall trim and wall paneling, all finished, so I don’t want to tamper with it anymore. So it will come down to a two-part door. The decision is now up to Junior. Still, thank you to everyone who gave it so much thought. Our son underestimated it or simply didn’t know because he hadn’t dealt with it in depth before. We are the helpers and have already worked some magic on the countertop. But we knew that in advance. Fortunately.
Nerusa
23 Feb 2017 15:32
would there be no issues with the Vario system? Or does anyone have different experiences?
It obviously looks good though
[MEDIA=YouTube]ciXh54ZhdBw[/MEDIA]
Thank you very much – Nerusa
MarekKrug
2 Mar 2017 12:28
And what was the outcome of the decision?
Casimyr
5 Mar 2017 11:06
Hello dear community,
I am new here and plan to order my Metod kitchen next week.
I had originally decided on the Bosch SPV50E90EU dishwasher.
After reading a lot online and here in the forum about issues with the fronts, I’m now completely unsure about what to do.
Can anyone tell me if I can properly install this dishwasher using ERSÄTTARE or Behjälplig rails? Do I need to cut the fronts myself, or is there a ready-made solution from Ikea?
If necessary, could someone recommend another appliance? 45cm (18 inches) wide, max. 500 EUR, brand-name product?
Many thanks and best regards,
Casi
