ᐅ Dishwasher front panels
Created on: 26 Mar 2014 11:26
Sektionschef
Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
david_87
6 Dec 2016 15:49
Thanks
But I only started looking into this topic today. I had in the back of my mind that the dishwasher was specifically designed for IKEA kitchens, so the shock from such a message was quite big. I need to take a closer look at the situation when I have more time... I don’t live in the house yet, only the kitchen has already been installed.
IKEA-Freund
6 Dec 2016 16:27
A video showing the installation is linked at the end of the video shared by IKEA-Experte: [YouTube:2z9hssxs]HM0kKEKzn6o[/YouTube:2z9hssxs]
The movement of the front panel can also be seen at the very end of the video. To allow the front panel to slide smoothly, the mounting screws for the handles must be countersunk.
IKEA-Freund
david_87
7 Dec 2016 08:19
So, yesterday I finally had a chance to take a closer look at everything... The system itself works, I can open the dishwasher fully, although with some resistance in parts (no idea if that’s normal).
But here comes the real surprise: I removed the front panel and noticed that one of the installers probably broke a plastic hook for the hinge and just pushed the front panel back in, so it was basically hanging on only 3 instead of 4 points. Since the hinge is now essentially working on only one side, it’s no wonder the whole thing doesn’t operate smoothly... Luckily, I have a 3D printer at work... Man, oh man.
Is the front panel supposed to be fastened somehow, or can it always be pulled straight upwards to remove?
For now, I’m modeling the plastic hook and printing it again.
Thanks
IKEA-Freund
7 Dec 2016 08:42
The damaged hook should be ordered and installed as a replacement part by the installers at their own expense.
IKEA-Freund
david_87
7 Dec 2016 09:16
The damaged hook should be ordered and installed by the installers as a spare part at their own expense.
Regards,
IKEA-Freund
I already know the answer—there will be endless back and forth, and no one will want to take responsibility... Luckily, I already have the part on my printer, since this kind of thing is part of my job.
_
_michi
7 Dec 2016 09:38
I have installed a Neff GX662 in my kitchen (with a Vario hinge), which worked well except for the BLANKETT handle, which I had to replace with a different one. Now I have a question regarding the plinth boards. The feet of the dishwasher extend slightly beyond the feet of the METOD cabinets. How would you recommend installing the plinth board in this situation?
Thank you!
