ᐅ Dishwasher front panels
Created on: 26 Mar 2014 11:26
Sektionschef
Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
kaderekusen
19 Oct 2016 21:27
Oh man, that's true, it still needs to have a variable hinge.
It's difficult to find all 4 points at once.
timeLight (time projected onto the floor instead of color)
Cutlery drawer
86.5 cm (34 inches) height
Variable hinge
If possible a
IKEA-Experte
19 Oct 2016 23:09
The models were not designed for installation in a METOD kitchen, but for tall cabinet installation without a recessed plinth. In this situation, the Timelight is not visible, which is why only the Infolight is available.
Standard kitchen manufacturers use tall cabinet carcasses with a height of 78 cm (31 inches), so there is no need for an adjustable hinge when installing under the countertop.
Salidis
22 Nov 2016 20:03
when I search on Idealo for 86.5cm (34 inches) high appliances with a variable hinge, I find more models than are listed here – for example, some from Siemens for well under 500 euros. Are there other reasons why these don’t fit?
IKEA-Experte
22 Nov 2016 22:26
The model under 500 € is also listed above. The list does not claim to be complete, and new models are constantly entering the market. Information on Idealo is sometimes inaccurate. Before purchasing, you need to carefully check whether all desired features are actually included.
david_87
6 Dec 2016 10:16
I also bought the Siemens SX76P030EU dishwasher with a Vario hinge. Since I had the kitchen installed, the kitchen fitter now says that the front panel hits the cabinet!!!
Is there any trick to this? It’s a full 80cm (31.5 inches) front panel. Maybe I just need to press a bit further downward when the dishwasher is open and then the front panel moves forward? Maybe someone can help me.
Thanks
IKEA-Freund
6 Dec 2016 11:21
Is it just passing by or does it actually touch? According to the dimension sketch, fronts up to 80 cm (31.5 inches) should fit. Take a look at the installation manual (unfortunately, Siemens does not offer it for download, but it should be included with the appliance).
Regards,
IKEA-Freund
