Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
Sektionschef
Samson_90282 Jan 2016 18:37No, unfortunately that is too expensive for me as well, I can’t go above 650.
That’s why I’m interested in the two specific models mentioned, or rather my actual question: does a 775mm (30.5 inches) variable hinge fit an 80cm (31.5 inches) cabinet carcass?
IKEA-Experte2 Jan 2016 18:54Ah no, it has to be specified as 800.
Samson_90282 Jan 2016 19:50May I ask what the purpose of the adjustable hinge is then? If the front dimensions already match the front anyway?
But thanks anyway, obviously I still need to spend some more time looking for my dream dishwasher (= cutlery drawer, Zeolith drying, quiet, A ).
IKEA-Experte2 Jan 2016 20:10 If the front dimensions already match the front? I don't understand the question.
With your requirements, you will have to spend more.
Samson_90282 Jan 2016 20:14Oh, I didn’t know that the drawers can also be purchased separately.
Well, I always thought that the variable hinge is meant to solve issues like those that occur with Ikea fronts, and that if you buy a front that fits the size properly, you wouldn’t need the variable hinge anymore.
Obviously, that’s not the case—that’s actually why I wanted to ask here again.
IKEA-Experte2 Jan 2016 20:19If you buy a front in the correct height, you do not need a variable hinge, but the size of the front in a fitted kitchen is determined by the kitchen cabinets, which is 80 cm (31.5 inches) for Metod.
The cutlery drawer cannot be retrofitted on all models.
