Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
Sektionschef
kaderekusen15 Oct 2016 14:11Since it’s unfortunately not possible to pin posts, here are some suitable BSH models again:
Siemens:
SX878D04PE
SX778X16TE
SX778D01TE
SX76P030EU
Bosch:
SBE88TX16E
SBE63N20EU
SBE65N91EU
SBE68TX06E
Neff:
S727P80X1E
S72P69X0EU Are these all the models? Or are there more?
I’m looking for one with a drawer for dishes, without much modification. So one that works with Stefan’s solution (simply mount the front a few centimeters higher after lowering the appliance deeper... Ideally around 700 euros.
But all from this list are almost 1000 or more...
At least the ones with such a drawer.
kaderekusen15 Oct 2016 14:14Oh, Nachtvogel has found something nice there...
SBV69N70EU from Bosch...
Which method could I use to install it?
IKEA-Experte15 Oct 2016 14:52The manufacturer's suggested retail price is over €100, but the actual price is significantly lower. Nachtvogel’s machine requires the Stefan method. According to the specifications, the entire kitchen must then be installed with a 9 cm (3.5 inch) baseboard height. There have been no reports yet that it also works with 8 cm (3.1 inch).
Schmidti8215 Oct 2016 16:10Nachtvogel has installed their dishwasher as a tall unit. I believe it is above a 40cm (16 inch) pull-out drawer.
kaderekusen19 Oct 2016 17:24So, the washing machines that fit directly into the Metod kitchen cabinet without any modifications (Steffan method, hinges, etc.) needed to have a minimum overall height of 86.5 cm (34 inches)?
Why doesn’t the SBV69N70EU fit? It is also 86.5 cm (34 inches) high.
IKEA-Experte19 Oct 2016 19:07It does not have a variable hinge.
Built-in washing machines have a front-opening door, so the height is not very important.
