ᐅ Dishwasher front panels
Created on: 26 Mar 2014 11:26
Sektionschef
Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
kabu
29 May 2015 09:37
Do you mean the cover caps? Where did you order them from?
Spanni
29 May 2015 09:39
IKEA online spare parts shop...
Part number is: 128891
I got it from the instructions for Behjälplig
https://www.ikea.com/de/de/assembly_instructions/behjalplig-gleitscharnier-vollint-geschirrsp-__AA-1083468-3_pub.pdf
kabu
29 May 2015 09:46
Interesting, at IKEA Austria this cannot be done online; you have to contact customer service...
Spanni
2 Jun 2015 14:37
You won’t find a complete list anywhere... I got mine from a large price comparison website. You can also filter there.
Then I checked my favorites to see if the foundation fits...
kleinho
29 Jul 2015 12:15
first of all, I want to mention that installing the Siemens SX76P030EU was trouble-free. We chose the Blankett handles, which initially caused a lot of scratching. Our carpenter then beveled (sanded) the edge of the handle strip on the back. After that, I applied Tesa Extra Power repair tape over the edge, and now everything works perfectly! In my opinion, cutting off the handle is not necessary! I even suspect that just applying tape alone would have been enough; maybe fabric tape would be better, but I wasn’t completely sure because of its thickness!
küchenprofi
17 Aug 2015 19:26
Thank you all!
Did I understand correctly that the higher the front panel is, the more it extends below at the dishwasher door and the more it “slides” under the appliance when the door is opened?
How does this work with XXL dishwashers? Larger fronts should be possible there. Can the front panel be mounted directly on the dishwasher door for Metod kitchens?
Sektionschef
WRONG… The higher it is, the more it extends above…
