ᐅ How can I clean matte IKEA Metod cabinet fronts without leaving streaks?
Created on: 9 Mar 2023 08:12
keopi
keopi
9 Mar 2023 08:12
Hello everyone, I have matte painted IKEA Metod kitchen cabinet fronts and I’m facing the problem of cleaning them without streaks or smudges. I have already tried regular all-purpose cloths and mild cleaners, but often an unpleasant haze remains that spoils the appearance. I’m especially interested in tips on which products to use and in what order to proceed to thoroughly and streak-free clean matte finished fronts, without damaging or harming the surface. Has anyone had similar experiences? What are your tried and tested methods or products?
sifope
9 Mar 2023 08:49
keopi schrieb:
I have already tried using regular all-purpose cloths and mild cleaners, but often an unpleasant haze remains
How exactly do you define "mild"? Often, the issue is less about the cleaner and more about the cleaning method and the cloth quality. Microfiber is popular, but especially on matte painted surfaces, residues can form if the cloth itself isn’t suitable.
Could you also describe how you rinse and dry your cloth?
Stubborn dirt or detergent residue often remains, which is then perceived as streaks.
Bagupo
9 Mar 2023 09:17
Use a soft microfiber cloth, slightly dampened with clean water. Do not use any cleaning agents! Then polish with a dry, clean cloth. Done.
andre3
9 Mar 2023 10:05
For the proper cleaning of matte Metod fronts, I recommend a clear procedure:
- First, remove loose dirt with a soft, dry microfiber cloth.
- Then, lightly dampen a microfiber cloth with distilled water to avoid water spots caused by mineral deposits.
- For heavier dirt, a small amount of a mild, pH-neutral cleaner without alcohol can be used.
- After cleaning, gently buff the surface in circular motions with a dry microfiber cloth to prevent streaking.
Important: Do not use abrasive or solvent-based cleaners, as these can damage the matte finish.
keopi
9 Mar 2023 10:46
I use cleaning agents that are labeled on the packaging as "for sensitive surfaces" and are generally described as neutral, but usually contain a mild surfactant.
sifope schrieb:
Can you also describe how you rinse and dry your cloth?
I rinse it under warm tap water and then wring it out several times before use. Afterwards, I usually hang it up to dry or use it slightly damp.
Maybe the issue is related to how you wring or apply the cloth. Perhaps it’s better to keep the cloth just barely damp? I will also try the other tips like distilled water and pH-neutral cleaner, thanks!
islaron
9 Mar 2023 11:28
I can add: After cleaning, it often helps to have a bottle of clear water and a dry microfiber cloth ready, so you can wipe the surfaces again with a lightly damp cloth and then polish them dry. This helps prevent many streaks.
