Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
Sektionschef
Schraube198617 Apr 2015 22:42Hello IKEA expert,
thank you for your quick and precise response!
From your point of view, would it also be possible to set the Metod legs to 9 cm (3.5 inches) instead of 8 cm (3 inches) to gain the 1 cm (0.4 inches) that is missing at the end?
If the dishwasher wasn’t quite so new, I would buy a new one with a Vario hinge...!
By the way, has anyone already seen pictures of the version with 60 cm (24 inches) and 20 cm (8 inches) fronts in real life?
IKEA-Experte17 Apr 2015 22:58A link to an image with the split front and ERSÄTTARE should be somewhere in this thread.
Setting the feet to 9cm (3.5 inches) is not a problem. That would be the 5th option if the front overlaps by 7.5cm (3 inches) at the top.
Schraube198617 Apr 2015 23:02Hmm, the question is whether the 1cm (0.4 inches) clearance from above is visible....! Well, it's all a bit unsatisfactory!
I am currently planning a Metod kitchen but don’t have any appliances yet. I need to work with a somewhat limited budget, so the dishwasher should not cost more than 500 euros.
I have been reading a lot here, and the best options seem to be
a) Large-capacity dishwasher with an air gap on top. Fill the air gap with boards or something similar.
b) Dishwasher with a variable hinge (e.g., Siemens SX76P030EU). However, I can’t find any dimension sketches for this. Can the dishwasher be adjusted up to 880 mm (35 inches) in height?
c) IKEA dishwasher. These are only 81.8 cm (32 inches) high as well. How is it solved there?
There doesn’t seem to be a neat method for a standard-sized dishwasher? Either using the Stefan method with an 8 cm (3 inch) front overlap or the Behjälping hinge, where the Metod front will no longer be flush with the dishwasher front because the dishwasher has to be raised?
Is https://www.hausbau-forum.de/images/b3814f2f5f54881238e4f6a7e5e71208.jpg really the only solution for standard-sized dishwashers? Or was that installed incorrectly?
I’m getting a bit frustrated...
Thanks in advance
Thanks in advance
IKEA-Experte19 Apr 2015 16:44Hello,
choose the Siemens SX76P030EU. The price is right, and it fits without any issues if you use a full 80cm (31.5 inches) wide front.
The dimension drawing is available on Siemens’ website under Downloads.
The Stefan method works with an 8cm (3.1 inches) overhang for the 82cm (32.3 inches) high BSH appliance only if the kitchen plinth is raised to at least 9cm (3.5 inches). (With other manufacturers and older models, it might be different).
Assistance is no longer available. IKEA no longer offers solutions for third-party appliances. How it works with IKEA appliances can be seen in the installation manuals.
