ᐅ Dishwasher front panels
Created on: 26 Mar 2014 11:26
Sektionschef
Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
IKEA-Experte
20 Mar 2015 22:20
Hello, the handle is installed in the same position as on the cabinets. Otherwise, it would look odd.
I don’t quite understand the rest. When installing in a kitchen with 80cm (31.5 inches) high fronts, RESONLIG is needed. It comes with a drilling template.
IKEA-Experte
21 Mar 2015 14:52
If you find a way to install an 80cm (31.5 inches) high continuous front without RESONLIG and still allow the door to open fully, please share how you did it here.
Coletrickle_7808
4 Apr 2015 11:24
How is this actually handled with the Vario hinge when the front consists of several parts?
Doesn't the connecting rail between the individual fronts get in the way?
Are all accessory components available from Siemens/Bosch/Neff?
Leuchte_4301
4 Apr 2015 17:26
How is this handled with the Vario hinge when the front consists of multiple parts?
Doesn’t the connecting rail of the individual front panels get in the way?
The Vario hinge is integrated into the dishwasher front. On the front panel (Ikea), four plastic pegs are screwed in, which are recessed and fixed into the dishwasher front. There is a maximum clearance of 1 mm (0.04 inches) between the dishwasher front and the door. The mounting materials (four holder screws) are included with the dishwasher.
Mounting a front made of several individual parts is not possible unless the connecting rail for the front elements is routed into the individual front panels. An attached or screwed-on connecting rail does not fit between the dishwasher and the front due to the minimal clearance.
IKEA-Experte
4 Apr 2015 18:16
It should also work if you use connector strips and place something of the same thickness under the 4 holders.
The best option would be to dowel the fronts or have them professionally doweled.
Coletrickle_7808
5 Apr 2015 11:47
Okay... understood. Wouldn't it also be an option to attach the variable hinge to the IKEA connectors? There were users here who have the variable hinge and still use a split front. I would like to have a 40/20/20 front.
Aside from that: Why are the dishwasher fronts no longer listed on IKEA’s website?
