ᐅ How can I clean matte IKEA Metod cabinet fronts without scratching them?
Created on: 16 Dec 2024 07:23
DetlefsonD
Detlefson16 Dec 2024 07:23Hello everyone,
I recently installed matte IKEA Metod fronts in my kitchen. I’ve noticed that maintaining the surface is more challenging than expected. Since matte fronts are very susceptible to scratches, I want to avoid damaging them with unsuitable products or methods.
My specific question is: How do you clean your matte IKEA Metod fronts without causing unattractive scratches or dull spots?
In particular, I’m interested in:
- Which cleaning agents are suitable and safe for the matte surface?
- What tools (sponges, cloths) do you recommend?
- Are there any techniques or procedures that help minimize the risk of scratches?
I look forward to your combined experience and tips, as I want to keep the fronts in good condition for as long as possible.
Hello Detlefson,
I think your question is very well formulated, and I have some experience with matte surfaces, including IKEA Metod fronts. Here is my suggestion in several steps:
- Cleaning agents: Use lukewarm water with a small amount of mild dish soap. Avoid abrasive cleaners or harsh chemicals, as they can damage the matte surface.
- Tools: A soft microfiber cloth is best suited. Do not use rough sponges or steel wool.
- Technique: Always wipe gently in circular motions, but avoid heavy rubbing.
Common mistakes:
- Rubbing dry surfaces often leads to small scratches.
- Avoid spraying cleaning products directly onto the front; it is better to moisten the cloth instead.
If you follow these tips, you should be able to clean the matte surface gently.
Summary: Lukewarm water + little dish soap + soft microfiber cloth + gentle wiping.
Common mistakes:
I would like to add an important point to Jensson’s remarks. Matte surfaces in kitchens are usually coated with a delicate plastic layer. Therefore, it is advisable to avoid treating the fronts with hot water unnecessarily, as high temperatures can damage the protective coating.
Additionally, I recommend treating stubborn stains with a mixture of water and vinegar (1:1), as this preserves the matte finish better than aggressive cleaners. Afterwards, wipe with clean water and dry thoroughly.
The main cause of scratches is mechanical impact from coarse cloths or dirt particles, so remove dirt gently by dusting first.
Jensson schrieb:
Avoid spraying directly onto the front; it’s better to dampen the cloth.I think that’s a bit exaggerated. I’ve cleaned my matte Metod fronts for years by spraying directly on them, and they still look good. It might also depend on how harsh the cleaning product is. In many cases, it seems more about knowing the proper cleaning technique rather than avoiding spray mist.
Also, if you choose matte fronts, you accept that stains or streaks may appear. It’s definitely not a glossy disaster.
