Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
Sektionschef
Leuchte_43016 Apr 2015 16:26It should also be possible to use connecting rails and place something of the same thickness under the four supports.
The best solution would be to dowel the fronts or have them doweled.Hello,
Unfortunately, you cannot use spacer plates because when opening, the front will hit the dishwasher at the bottom. There is really very little space.
Dowel joining should work, but it requires very precise and accurate work. Also, the installation allows for very little tolerance. Without professional tools, I consider this very difficult.
Coletrickle_78086 Apr 2015 18:29For practical reasons, I will go with a simple front. However, I find it strange that IKEA no longer offers any fronts to choose from. Odd. Now, you can only select matching doors for the dishwasher under the "Doors" tab. Previously, there used to be separate dishwasher fronts available.
Leuchte_43016 Apr 2015 19:57For practical reasons, I will go with a simple front. However, I find it surprising that Ikea no longer offers any fronts to choose from. Strange. You can now only select matching doors for the dishwasher under the “Doors” tab. Previously, there were separate dishwasher fronts.Take a look at the product PDF on page 75. Basically, there are no special fronts anymore. These are regular drawer panels that are just supplemented with additional mounting kits.
Coletrickle_78086 Apr 2015 21:15Thanks... but I will really go with a single front now. Things are so complicated. Is there anything else to consider regarding the dishwasher? It is an XXL model and has adjustable hinges; it is also installed between two cabinets.
Schraube198617 Apr 2015 20:52Hello,
I am currently installing a new Metod kitchen.
The wall cabinets are already in place.
I would like to install my 3-year-old Siemens SN65T090EU dishwasher into the new kitchen.
Unfortunately, there is a problem now.
Option 1:
When I planned the kitchen, the BEHJÄLPIG soft-close hinge was still available.
Does anyone know if and when it will be back in stock or if there are alternatives from other suppliers?
Option 2:
My dishwasher is designed for a toe kick height of at least 9cm (3.5 inches), but the Ikea toe kick is only 8cm (3 inches) high.
So, the only option left would be to screw the dishwasher down completely and install the base cabinets 1cm (0.4 inches) higher, creating a 1cm (0.4 inches) gap above the toe kick panel.
Do you think this gap would be visible from above, or can you think of another solution?
Thanks and best regards,
Schraube1986
Option 1:
Option 2:
Schraube1986
IKEA-Experte17 Apr 2015 22:01Hello, the 90 mm (3.5 inches) is not a minimum plinth height. The appliance is at least 815 mm (32 inches) tall, and the front panel can be a maximum of 725 mm (28.5 inches) tall. This means that with the tallest front panel, there must be a minimum gap of 90 mm (3.5 inches) between the floor and the front.
Behjälplig is no longer available, and as far as I know, there will be no replacement. Last week, I still saw one in the clearance section at IKEA Frankfurt, where it had been for at least two weeks. In any case, it’s worth checking the clearance section and asking customer service.
But what should you do if you can’t find one anymore?
1. Buy a new dishwasher.
2. Use a 60 cm (24 inches) by 20 cm (8 inches) front panel with ERSÄTTARE.
3. Live with a smaller front panel.
4. Make something similar to BEHJÄLPLIG yourself.
