ᐅ Is it possible to replace Ikea Metod cabinet fronts yourself?
Created on: 21 May 2024 08:37
enearon
Hello everyone, I have a more detailed question regarding IKEA Metod kitchen fronts: Is it possible to replace the fronts of Metod cabinets yourself without professional help? Specifically, I am interested in whether changing the fronts is straightforward when existing fittings, such as the special hinges and handle systems, are already installed, or if there might be unexpected challenges. How complex is the replacement in terms of tools needed, time required, and possible adjustments, for example regarding fit and installation? I have basic DIY skills but want to make sure nothing goes wrong. Looking forward to your experiences and advice!
Jensson
22 May 2024 07:15
Hello enearon,
here is a simple step-by-step guide on how I personally replace Ikea Metod fronts. I find this makes the whole process easier to estimate:
- Step 1: Carefully remove all existing fronts. Usually, this means loosening the screws on the hinges with a Phillips screwdriver, being careful not to damage the cabinet.
- Step 2: Check if the screw holes are still solid. If not, stabilize them using wooden dowels or solutions like those described by flo-Theres.
- Step 3: When changing handles, measure the holes precisely and drill new ones if necessary. Never simply enlarge the old holes.
- Step 4: Adjust the new fronts as needed, snap in and secure the hinges.
- Step 5: Adjust the doors using the screws on the hinges: side to side, up and down, and front to back.
One thing many overlook: After the replacement, always check that all doors have at least 1–2 mm (0.04–0.08 inches) clearance from adjacent doors or drawers, otherwise they might stick when opened or pulled out. This can happen during replacement if the fronts are slightly thicker.
Good luck!
meGreg
22 May 2024 08:32
Hello everyone 😃
I think it’s great that with a bit of patience you can manage things like this yourself at IKEA! My tip for all motivated DIYers: Make sure to hold the new cabinet fronts in place first before fully screwing them in. Sometimes the perfect alignment is just a matter of a few millimeters (inches), and careful adjustment using the hinge can quickly fix that.
For worn-out screw holes, I recently just applied a bit of wood glue with a toothpick, let it dry—and voilà, everything was stable again. This way, you can avoid having to buy new hinge units if the existing ones still work.
In the end, the effort is worth it because the kitchen feels like new again with the new fronts (and new handles as a bonus). 👍
Dustin
22 May 2024 09:11
Replacing cabinet fronts yourself is doable. Loosen the screws, remove the front, and attach the new front. If the screw holes are worn out, fill them with wood glue and wooden dowels, let it dry, then screw in again. Adjust the hinges until the door fits properly. No rocket science.
Davidleo
23 May 2024 10:47
Hey, I did this last week and just want to say: It’s really fun to refresh the kitchen like this! Especially when you see the new look – matte black is super stylish! 😍
Especially if the old cabinet fronts have been in use for several years: No worries, with wood glue and a few simple tricks, it works really well. Adjusting the doors can be a bit fiddly at first, but after that, they close smoothly again! You really feel like a DIY champion afterwards 💪
Nathanaelk
23 May 2024 11:53
Davidleo schrieb:
Adjustment is a bit fiddly at first, but after that the doors close very smoothly again!
Exactly! People often underestimate how precise the hinge adjustment system is. I recommend having a stable work surface and a good small Phillips screwdriver ready for the adjustment. By turning the adjustment screws, you can fine-tune the height, depth, and lateral offset down to the millimeter. It takes some time, but in the end, it perfects both the door’s function and appearance.
Finally, if you have any further questions specifically about the screw techniques or the hinges, just ask. I have already renovated several Metod kitchens and can definitely help.
