Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
Sektionschef
deluxe_132822 Apr 2015 12:24Ok. That sounds plausible. Thank you!
Can I also use a standard door, does anyone know?
IKEA-Experte22 Apr 2015 12:29Yes, you can use the standard door. At the hardware store, there are 35 mm (1.4 inches) wooden plugs available. You can glue these in to cover the holes.
deluxe_132822 Apr 2015 12:37Which holes exactly are you referring to that will form between the other cabinets and the dishwasher?
And do the drill holes on the standard door align correctly for this?
According to the manufacturer, a door with a maximum width of 717mm (28 inches) can be installed on a 60cm (24 inch) wide cabinet.
I’m a bit concerned about ordering everything now and then finding out nothing fits; the lady yesterday really confused me...
deluxe_132822 Apr 2015 13:22Do I also need finishing strips for the floor at the door?
Fresendelf22 Apr 2015 13:34So: By holes, we mean the pre-drilled holes used to attach the door hinges. These holes are only visible from the back and won’t be seen once installed on the dishwasher. At hardware stores, you can find suitable caps to cover these holes.
The manufacturer’s specifications match the Faktum door. So, installation should be straightforward once the holes (see above) are covered.
You can ignore what the lady said yesterday, as she was only referring to the new Metod fronts. With Faktum, due to the door height of 70cm (28 inches), there have never been major issues with appliances from other brands.
IKEA-Experte22 Apr 2015 13:55Do I actually need floor trim strips at the door as well?You only need a baseboard running along the entire wall.
