ᐅ External refrigerator in Ikea Faktum built-in cabinet
Created on: 7 May 2016 22:32
Tobiassss
I need to replace my refrigerator soon. So far, I had a small one, but now I want to install a fridge-freezer combination. The niche dimensions fit the new one, but right now I see potential issues with the doors. I have a 211cm (83 inches) cabinet divided into three sections: the lower door is 60x70cm (24x28 inches), the other one is 60x90cm (24x35 inches), and the top one is about 60x34.5cm (24x14 inches).
The problem is that the 70cm (28 inches) side isn’t exactly 70cm but only 69.4cm (27⅜ inches), whereas the fridge drawing specifies 69.7cm (27½ inches) for that dimension. Has anyone else installed this kind of setup?
I’d have liked to include a picture, but I wasn’t able to do so....
The fridge-freezer unit is 177cm (70 inches) tall, with the freezer compartment at the bottom and the fridge on top...
IKEA-Experte
8 May 2016 10:54
Then the cabinet would simply be a bit taller than the wall cabinets.
Take a look at the Liebherr ICUNS 3314 Comfort NoFrost or KI86NVS30.
Tobiassss
9 May 2016 20:04
Then the cabinet would just be a bit taller than the wall cabinets.
So, I took some measurements... It won’t fit the way I planned. But I found another series from Siemens/Bosch that should fit. The KI87 or KIS87 models ought to work.
Thank you all!
IKEA-Experte
9 May 2016 20:20
You are dealing with the challenges of a very small freezer compartment, and you need to assemble the fronts very securely if the appliance has overlay hinges.
Küchenprofessor
10 May 2016 02:15
I worked for 9 years selling Ikea kitchens, so I am familiar with Faktum. The refrigerator fits a standard size that is available from almost every manufacturer, including Ikea with Faktum. I have personally installed external refrigerators with a height of 178cm (70 inches) in Faktum cabinets.
The last refrigerator of this size at Ikea was produced by Electrolux. Neither Electrolux nor Whirlpool manufactures custom sizes for IKEA, as it would not be economically viable.
Tobiassss
10 May 2016 06:39
I worked in IKEA kitchen sales for nine years, so I’m familiar with Faktum. The refrigerator fits a standard size that is available from almost every manufacturer, including IKEA’s Faktum line. I have personally installed external refrigerators with a height of 178cm (70 inches) into Faktum kitchens. The last model of this size at IKEA was produced by Electrolux. Neither Electrolux nor Whirlpool manufacture custom sizes for IKEA, as it wouldn’t be economically viable.
Yes, but what exactly is the standard size and the common division of door dimensions? I understand the total height of 178cm (70 inches), but according to the technical drawings of individual refrigerators, the bottom door panels measure approximately 60 to 72cm (24 to 28 inches). Wouldn’t door panels above 69cm (27 inches) cause issues when fitting, or am I misunderstanding something? Do you remember which models from other suppliers you planned or installed there?
Since you worked at IKEA, what were the reviews like for the refrigerators offered there?
IKEA-Experte
12 May 2016 14:44
The kitchen expert has probably only installed appliances with drop-down door mechanisms in FAKTUM.
