Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
Sektionschef
IKEA-Experte23 Apr 2015 20:01I haven’t compared everything point by point, but I couldn’t find any differences. Since the device is not listed on the German Siemens website, it might be an older model or a version made only for export. Siemens should be able to provide you with that information.
Hello everyone, I have now read through the entire thread and have learned a lot about dishwasher fronts.
We have a Välgjord dishwasher that already has integrated Vario hinges. However, I need the drilling template for attaching the front panel. Does anyone happen to have one and could share the measurements or take a photo? That would be great.
Actually, one should make a list of which dishwashers (apart from the Ikea ones) are still compatible...
I'm currently looking for one, as the delivery company is taking back my old one (very accommodating) because I can't attach the front panel...
I'm searching now and have come across the Bosch large-capacity dishwashers.
SX64M030EU... Unfortunately, I can't find any information from the manufacturer about the adjustable hinge or panel size... Does anyone know anything about this?
Spanni
Spanni
IKEA-Experte26 May 2015 15:52That one won’t work. For example, SX878D04PE is suitable. You can find the dimensional drawing in the downloads section of the product description on the Siemens website. There, the front height must be specified as up to 800mm (31.5 inches).
Juliette W26 May 2015 19:18A few days ago, we had the Siemens SX778D01TE installed. It went smoothly without any issues. You don’t even need a handle (so no need to recess any screws), as the door opens at the top with a gentle push. There is plenty of space inside, and the dishes come out very clean.
