ᐅ Are there any upcycling tips for IKEA Hemnes cabinet fronts?
Created on: 7 Sep 2020 08:37
Gonaro
Gonaro
7 Sep 2020 08:37
Hello everyone, I am currently exploring the topic of upcycling IKEA Hemnes fronts, which are quite sturdy and often used as a base for custom furniture. I am particularly interested in whether anyone in this forum has experience or tips on how to enhance Hemnes fronts effectively without damaging the material or requiring too much effort. For example, I’m looking at surface treatment options such as painting, applying adhesive films, or other creative redesign ideas. Are there any proven methods or tricks that specifically suit the surface texture and finish of Hemnes fronts? I look forward to practical advice and exchanging ideas!
KIN42
7 Sep 2020 09:21
The Hemnes fronts are actually very sturdy, which makes upcycling easier. A proven tip is to lightly sand the surface before painting to improve adhesion. Be sure to use a primer suitable for painted wood surfaces. For the paint, I recommend acrylic or acrylic-based paints, as they remain flexible and are less likely to chip. Vinyl films are also an option, but good preparation and ensuring bubble-free application are essential.
nanidra
7 Sep 2020 10:02
KIN42 schrieb:
The Hemnes fronts are indeed very sturdy, which makes upcycling easier.
Sturdy, yes, but people often overestimate how well the paint can be removed or renewed. Most assume that simply painting over it is enough – it’s not. Honestly, for me, upcycling IKEA fronts is more of a creative illusion. You need to invest significant time beforehand, and even then, the results are often limited by the original surface.
Roberta
7 Sep 2020 11:19
Chalk paint works well for the Hemnes fronts. It doesn’t necessarily require sanding and gives the furniture a vintage look. Afterwards, seal it with wax to protect against moisture.
GAGRAHAM
7 Sep 2020 12:44
I covered my Hemnes fronts with self-adhesive wallpaper, and it looks really fresh and is a lot of fun! Just measure carefully, apply it smoothly, and then trim precisely with a utility knife. Don’t worry, it’s inexpensive and completely transforms the furniture. Definitely give it a try, everyone!
sancamille
7 Sep 2020 13:15
Only lightly sand the paint layers; do not remove them completely to keep the front stable. Otherwise, follow the usual renovation process with a special primer, then apply paint in the desired color. Simple and effective.
