ᐅ How do I repair scratches and dents on IKEA Metod cabinet fronts?
Created on: 6 Aug 2022 08:13
Q
quirin
Q
quirin
6 Aug 2022 08:13
Hello everyone, I have an issue with some scratches and dents on my Ikea Metod fronts, which have a matte white finish. The damage includes some surface-level scratches that are mostly visible only upon close inspection, as well as small dents caused by impacts. I don’t want to buy new fronts right away, so I’m wondering what options are available to discreetly repair or at least improve the appearance of these minor blemishes. Does anyone know of good materials and methods for treating these types of fronts? I was thinking about special repair kits, sandpaper, fillers, or paints but am unsure what is generally suitable, since these are relatively sensitive plastic fronts with a matte coating. I would also appreciate tips on surface preparation and finishing treatments. Thanks in advance!
KUDAISY
6 Aug 2022 08:57
Hello quirin,
Definitely a sensible question! Repairs on Ikea Metod fronts require some delicacy because they are usually made of MDF panels with a melamine resin-coated surface, which is matte.
Here is a step-by-step suggestion:
- Cleaning: First, clean the fronts with a mild cleaning agent to remove dust and grease.
- Sanding: Lightly sand the damaged area with 400-grit sandpaper – be very gentle to avoid further damaging the matte surface.
- Filling: For dents, you can use special water-based wood fillers that can be sanded after drying. It’s best to match the exact color; white or clear variants are available.
- Sanding & smoothing: After drying, very gently roughen the area with 600-grit sandpaper to even out the surface.
- Painting: Finish with a matte acrylic paint or spray paint in a matching color. Apply thin layers and allow them to dry.
Common mistakes are sanding too aggressively or applying filler too thickly, which makes the repair easily noticeable. It is important to handle each step carefully and check in between.
If you like, I can also provide advice on specific products. Good luck!
JORGERON
6 Aug 2022 09:23
Treat scratches with a white furniture touch-up marker and fill dents with wood filler, then apply a matte finish. Quick solution.
barda6
6 Aug 2022 09:47
Only sand gently, otherwise you will damage the matte surface. It’s better to apply a light filler and then use paint.
Q
quirin
6 Aug 2022 10:12
KUDAISY schrieb:
Typical mistakes include sanding too aggressively or applying the filler too thickly, which makes the result quickly noticeable.
Thank you, that sounds very helpful. Could you briefly explain how to best find the right color match for the paint? The color at IKEA is often not clearly defined, and a wrong shade probably stands out immediately on the matte surface.
KUDAISY
6 Aug 2022 10:43
Good question. For Ikea Metod fronts in matte white, the best approach is to use small test samples. Start by purchasing several small spray paints or acrylic paints in different shades of white (pure white, cream white, neutral white). Before applying, do small tests on a hidden edge or on one of the back panels.
It is important to allow enough drying time because the color often darkens slightly or becomes more matte as it dries. If possible, ask at the hardware store for RAL or NCS color codes, which will allow you to search for the matching shade online or at specialty retailers.
Sometimes, it also helps to touch up minor damage instead of repainting the entire surface if you want to reduce the risk of color mismatch.
