ᐅ How do I fix a squeaky IKEA Metod cabinet door?
Created on: 18 Mar 2023 08:13
Lenlasse
Lenlasse
18 Mar 2023 08:13
I have an IKEA Metod kitchen cabinet door that has been making a very unpleasant squeaking sound every time it opens and closes for some time now. The noise seems to come from the hinges, and I suspect they either need to be adjusted or lubricated. Since I don’t want to remove the door and I’m not exactly sure which parts are involved, my question to the community is: What is the best way to fix a squeaky IKEA Metod door? What tools and materials do I need for this, and are there any specific tips or recommendations for maintaining the hinges to keep the squeaking from coming back? A step-by-step guide would be great, ideally also with advice on whether I need to take the door off for this or if it can be done in place.
kasan
18 Mar 2023 08:47
Interesting question. Before we talk about repairs, are you sure the squeaking is actually coming from the hinges? Sometimes it can also be the rubber buffers or the mounting screws loosening and causing noise. I think it’s important to identify the exact cause before using lubricants or anything else, as this can sometimes be counterproductive—for example, if it attracts dust and makes the problem worse in the long run.
boelnu
18 Mar 2023 09:05
I can relate to that; those squeaky doors are really annoying. I had the same problem with my old kitchen. When it comes to tightening screws and lubricating, it can be a bit intimidating at first, especially if you're not exactly sure what you're doing. But don’t worry, you’ll manage it. Once the door is properly adjusted and the hinges lubricated, the satisfaction is even greater because the squeaking really goes away.
Tevin
18 Mar 2023 09:27
Hello, I can offer some tips on how to fix the squeaking on an IKEA Metod door. Basically, you are dealing with standard cabinet hinges that can either be maintained proactively or adjusted. Here are the main steps:
- Open the door carefully and inspect the hinge closely (both on the door side and the cabinet side).
- Tighten the screws on the mounting plate and the hinge if they are loose.
- If the hinges squeak when moving, squeak spray or silicone oil often helps.
- Use lubricants sparingly, preferably silicone spray, as it does not stick or attract dust.
- It is usually not necessary to remove the door completely, unless you want to replace the hinges entirely.
Important: Do not use WD-40, as it can often damage the mechanism over time.
Matthewt48
18 Mar 2023 10:02
I agree with that. It is also important to know the type of hinges used – IKEA often uses so-called clip-on hinges for Metod, which are easy to install. When adjusting, you usually turn the screws on the back of the hinge to ensure the door fits properly and doesn’t hang crookedly, which can also cause noise. In my experience, a combination of tightening screws, aligning the door, and then carefully lubricating it helps.
meGreg
18 Mar 2023 10:33
A small tip from my experience: sometimes the hinges aren’t the issue, but the contact between the door and the cabinet. If metal rubs against metal anywhere, that can also cause squeaking. Often, a small layer of felt, such as self-adhesive felt pads, can help when you can’t pinpoint the exact source of the squeak. And yes, lubricating is satisfying, but using the right product and the right amount is crucial!
