ᐅ Floor plan design shortly before submitting the building permit application
Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
As some users have requested before, I’m now starting a new thread with the current planning of our detached house, which is about to be finalized.
These are the preliminary drawings for the building permit / planning permission application, and I have one last chance to review them and point out any issues.
It still seems to me that there is less than 1.20m (4 feet) of space between the two wardrobes in the dressing room. Or am I seeing this wrong? Apparently, the rooms on the left and right were overlooked and not adjusted accordingly.
Two Velux ceiling spotlights are still planned to illuminate the upper floor hallway.
In the basement, on the right side in the upper room, a window similar to the one on the left basement side is an option.
We still haven’t decided on the T30 fire-rated door to the garage, even though it is shown in the plans. Most likely, for safety reasons and the limited use of the kitchen at the other end of the house, we will eventually forgo it.
User 11ant pointed out that the right window in child’s room 2 is suboptimally positioned. However, this could still be changed after submitting the building permit / planning permission application. Our architect thinks moving the window to the left would negatively affect the house’s exterior appearance. We’ll have to see about that.
Wickie schrieb:
When connecting the house and garage, it is mandatory!Are you sure? In my case, the building authority did not require this.R
R.Hotzenplotz13 Apr 2018 14:50The architect refers to the state building code of North Rhine-Westphalia (NRW).
R.Hotzenplotz schrieb:
the price for the requested door is EUR 3,605.70. A lot of money for a door that isn't necessary, firstly because it doesn't shorten any route, and secondly because it is redundant since there is a king-size porch between the gate and the door.
The price for the requested door is EUR 3,605.70.
Door Leaf
Door thickness approx. 50 mm (2 inches), door weight approx. 73 kg (161 lbs)
Dimensions
Clear opening measurement (TAM) 985 x 2110 mm (39 x 83 inches)
Opening direction
DIN left-hand
Edges
Square edges
Surface
White lacquer finish (spray painting)
Fire protection
T 30 according to DIN 4102 with building authority approval no. Z-6.20-1838
Smoke protection
Smoke protection according to DIN 18095, with test certificate and DIN type plate
Burglar resistance
RC 2 according to DIN EN 1627, with test certificate
Sound insulation
SSK 1 according to DIN 4109 (Rw,P 32 dB / Rw,R 27 dB)
Test climate
Test insert
Special insert
Locking
Standard locking
Rabbet
Rabbet 13.0 x 37.0 mm (0.5 x 1.5 inches)
Edge design
Foil edge
Hinges
2 built-in base hinges 2039/160/56 (VX), nickel-plated
Lock
Built-in lock, multi-point locking SB FH, 65 mm (2.6 inches) backset, silver-colored faceplate
Handle
With handle set, FH plastic handle, U-shape with short plate, black
Door closer
Geze TS 3000 V, EN 1-4, silver-colored, standard installation on hinge side without mounting plate for sliding gear
Floor seal
Built-in drop-down floor seal
Rabbet air restrictor
Hinge side with 2 built-in rabbet air restrictors
Magnetic contact
Magnetic contact eff eff 10365 (leaf and frame part built-in)
Frame
Herholz wooden frame (HSZ) for solid wall
Dimensions
Theoretical clearance TAM 985 x 2110 x 345 mm (39 x 83 x 14 inches)
Edges
Square frame edge and cladding
Surface
White
Hinges / hinge pockets
2 built-in hinge pockets, hinge pockets STV83/56 3-D, with cover plate, nickel-plated
Strike plates
3 strike plates for MFV SB, stainless steel bolt contact eff eff 878 built-in
Claddings
Claddings 22 x 50.0/50.0 mm (0.9 x 2.0/2.0 inches)
Sealing levels
Frame with 1 sealing level
Frame seal
Damping profile
Other equipment
Prepared for customer-supplied locking element
1.00 piece multi-point locking with emergency release (required)
1.00 piece cylinder Wilka profile cylinder 1463 L=35/40 mm (1.4/1.6 inches)
Installation of T30 door in masonry new build including special foamR
R.Hotzenplotz14 Apr 2018 16:01ypg schrieb:
Do you need help with anything else?No, in what way?
