ᐅ Floor plan design shortly before submitting the building permit application
Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
As some users have requested before, I’m now starting a new thread with the current planning of our detached house, which is about to be finalized.
These are the preliminary drawings for the building permit / planning permission application, and I have one last chance to review them and point out any issues.
It still seems to me that there is less than 1.20m (4 feet) of space between the two wardrobes in the dressing room. Or am I seeing this wrong? Apparently, the rooms on the left and right were overlooked and not adjusted accordingly.
Two Velux ceiling spotlights are still planned to illuminate the upper floor hallway.
In the basement, on the right side in the upper room, a window similar to the one on the left basement side is an option.
We still haven’t decided on the T30 fire-rated door to the garage, even though it is shown in the plans. Most likely, for safety reasons and the limited use of the kitchen at the other end of the house, we will eventually forgo it.
User 11ant pointed out that the right window in child’s room 2 is suboptimally positioned. However, this could still be changed after submitting the building permit / planning permission application. Our architect thinks moving the window to the left would negatively affect the house’s exterior appearance. We’ll have to see about that.
R.Hotzenplotz schrieb:
What don’t you like about the existing porch?In my opinion, it’s not necessary to have two ways to enter the house without stepping into the rain. I’d rather focus on making the main entrance more impressive—lights, decorations, a wider path, and so on.The garage door is connected to the alarm system. So the door between the garage and the house does not need to be connected; it is similar to an interior door. A central control panel with a time delay, for example in the wardrobe area, should be sufficient.
I'm glad I don't have to deal with this kind of thing. There are advantages to living at the end of the world in the middle of nowhere.
kaho674 schrieb:
In my opinion, you don’t need two ways to enter the house keeping your feet dry. So I’d rather make the main entrance more impressive. But it’s already as impressive as something by Glööckler
And if you don’t have a proper main entrance at this spot, it doesn’t make any sense at all. Exactly for that reason, I’ve been saying all along: if you pamper your garage door with such a canopy, you can also use it as the main entrance underneath.
R.Hotzenplotz13 Apr 2018 10:47The price for the requested door is EUR 3,605.70.
Door Leaf
Door thickness approx. 50 mm (2 inches), door weight approx. 73 kg (161 lbs)
Dimensions
Clear opening dimension (COD) 985 x 2110 mm (39 x 83 inches)
Opening direction
DIN left
Edges
Square edges
Surface
White lacquer finish
(spray lacquered)
Fire protection
T 30 according to DIN 4102 with
official building approval no.
Z-6.20-1838
Smoke protection
Smoke protection according to DIN 18095, with
test certificate and DIN type label
Burglary resistance
RC 2 according to DIN EN 1627, with
test certificate
Sound insulation
SSK 1 according to DIN 4109 (Rw,P 32 dB / Rw,R 27 dB)
Testing climate
Test insert
Special insert
Locking
Standard locking
Rebate
Rebate 13.0 x 37.0 mm (0.5 x 1.5 inches)
Edge design
Foil edge
Hinges
2 built-in hinges Basic
2039/160/56 (VX), nickel-plated
Lock
Lock installed,
multi-point locking SB FH, 65 mm (2.6 inches)
backset, silver-colored faceplate
Handle
with handle set,
FH plastic handle, U-shape with
short plate, black
Door closer
Geze TS 3000 V, EN 1-4, silver-colored,
standard installation BS without mounting plate for equalization
Bottom seal
Built-in drop seal
Rebate gap limiters
On hinge side with 2 built-in rebate gap limiters
Magnetic contact
Magnetic contact eff eff 10365 (door leaf
and frame part installed)
Frame
Herholz wooden casing frame (HSZ)
for solid masonry wall
Dimensions
theoretical COD 985 x 2110 x 345 mm (39 x 83 x 14 inches)
Edges
Casing edge and facings square
Surface
White
Hinges/Hinge pockets
2 built-in hinge pockets,
hinge pockets STV83/56 3-D, with
cover plate, nickel-plated
Strike plates
3 strike plates for multi-point locking SB,
stainless steel bolt contact eff eff
878 installed
Facings
Facings 22 x 50.0/50.0 mm (0.9 x 2.0/2.0 inches)
Sealing levels
Frame with 1 sealing level
Frame seal
Damping profile
Other equipment
Prepared for customer-supplied blocking element
1.00 pcs multi-point locking with A-opener (required)
1.00 pcs cylinder Wilka profile cylinder 1463 L=35/40 mm (1.4/1.6 inches)
Installation of T30 door in masonry, new construction including special foam
Door Leaf
Dimensions
Opening direction
DIN left
Edges
Square edges
Surface
(spray lacquered)
Fire protection
Z-6.20-1838
Smoke protection
Burglary resistance
test certificate
Sound insulation
Testing climate
Test insert
Special insert
Locking
Standard locking
Rebate
Edge design
Foil edge
Hinges
Lock
Lock installed,
Handle
with handle set,
short plate, black
Door closer
Bottom seal
Built-in drop seal
Rebate gap limiters
Magnetic contact
Frame
Dimensions
Edges
Surface
White
Strike plates
878 installed
Facings
Sealing levels
Frame seal
Damping profile
Other equipment
