ᐅ Floor plan design shortly before submitting the building permit application
Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
As some users have requested before, I’m now starting a new thread with the current planning of our detached house, which is about to be finalized.
These are the preliminary drawings for the building permit / planning permission application, and I have one last chance to review them and point out any issues.
It still seems to me that there is less than 1.20m (4 feet) of space between the two wardrobes in the dressing room. Or am I seeing this wrong? Apparently, the rooms on the left and right were overlooked and not adjusted accordingly.
Two Velux ceiling spotlights are still planned to illuminate the upper floor hallway.
In the basement, on the right side in the upper room, a window similar to the one on the left basement side is an option.
We still haven’t decided on the T30 fire-rated door to the garage, even though it is shown in the plans. Most likely, for safety reasons and the limited use of the kitchen at the other end of the house, we will eventually forgo it.
User 11ant pointed out that the right window in child’s room 2 is suboptimally positioned. However, this could still be changed after submitting the building permit / planning permission application. Our architect thinks moving the window to the left would negatively affect the house’s exterior appearance. We’ll have to see about that.
R.Hotzenplotz schrieb:
Do you think anything will come of it? I’m thinking of just letting it go.Maybe, maybe not.
I would give it a try.
What happened wasn’t right, and he should know that.
Does the site manager know everything his crew is doing on the construction site? He might have come by and seen the same thing you did. Maybe he wondered about it or was even pleased that he estimated so well?
If he knew, then at least you’ve expressed your frustration.
Bismarck is said to have remarked that it is better if people do not know exactly how laws and sausages are made. The "finish" during demolition involving digging and subsoiling is probably more common than the average person would consider proper. If the contractor is a good actor, then he is outraged.
R.Hotzenplotz27 Jan 2018 15:16I will receive a photo documentation and can use it to request a written statement. A phone call will not help in this case. The invoice has been paid, and the contractor does not expect any follow-up orders; nothing can be proven.
R.Hotzenplotz30 Jan 2018 21:25The earthworks were successfully completed today. Tomorrow, I will deliver the standpipe for the construction water, the temporary power supply will be installed, and then the structural builder will begin.
R.Hotzenplotz21 Feb 2018 19:43The heating installer called to say that now a heating load exceeding 2 kW is required, and the quotes for the heating system are likely no longer valid.
This is probably more of an issue between him and the general contractor. He claims it is due to the window sill height being changed from 100 cm (39 inches) to 86 cm (34 inches). However, the dimensions are also specified in the contract (except for an additional basement window commissioned, which hardly accounts for 2 kW).
