ᐅ Dishwasher front panels
Created on: 26 Mar 2014 11:26
Sektionschef
Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
stefan5613BB
4 Sep 2014 11:11
The Metod fronts fit directly on the XXL dishwashers when they are installed correctly: Normally, these dishwashers only accommodate fronts up to 775mm (30.5 inches) wide, while IKEA’s 800mm (31.5 inches) fronts hit the dishwasher’s base when opened. Normally means that the dishwasher is installed so that it meets the countertop (or another shelf) at the top. Now, new and unusual: lower the dishwasher all the way to the floor, if necessary remove the rear foot extension, and fully close the top 3cm (1.2 inches) gap with shelves. The 25-30mm (1 to 1.2 inches) excess length of the front will now be at the top, which must be considered when installing the handle. Stefan
jelimi
4 Sep 2014 11:28
I don’t understand what you are all writing here.
@ Stefan, why does something need to be filled with soil when using XXL machines?
There is also no need to remove any floor extensions.
Take a look at the picture in my gallery, everything can be done with fronts.
Regards
IKEA-Experte
4 Sep 2014 11:57
Stefan describes a way to install fully integrated XXL dishwashers with a maximum front height of 775 mm (30.5 inches) without assistance.
The last post by Sektionschef refers to semi-integrated appliances.
Aronito
6 Sep 2014 15:50
I am Dutch and over the past few months I have been looking for information here and on the English Ikeafans forum. Yesterday, I installed an IKEA Metod kitchen with a Bosch dishwasher. It is an XXL Maxiline model. I have uploaded 3 photos in my album for everyone.
Sorry for my German, but I think you will understand it.
Combination:
Bosch SBV90E00NL
Helpful
Challenging
Ringhult high gloss white
Blankett handle
stefan5613BB
6 Sep 2014 22:07
@ Aronito
You could also have lowered the dishwasher all the way down (ALL the way!), possibly removing the rear foot extension first. Then you can mount the front panel directly onto the door, without that strange auxiliary support or something similar.
To prevent it from tilting when opened, only the gap at the top needs to be closed. Siemens offers suitable brackets for around 90€ (about $100), but two old shelves, slats, tile leftovers, ... will work just as well.
Stefan
jelimi
7 Sep 2014 11:44
I highly doubt that will work. The gap between the bottom edge of the door and the floor is much larger than the gap between the bottom edge of the door and the dishwasher when you open it.
The attached front panel will then hit the machine, and you won’t be able to open the door.
Take a look at the third picture from Aronito to see how high the front panel has to be lifted.
