Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
Sektionschef
IKEA-Experte29 Jan 2015 19:11Thank you for the report and the pictures. Additionally, I would like to mention that in the model shown in one of the pictures, the panel is mounted awkwardly with three screws on one side. However, there are models from Siemens/Bosch/Neff where the front panel is attached differently, so the installation instructions should be reviewed before purchasing the dishwasher.
Sektionschef29 Jan 2015 20:03Thanks, Bines!
Which Siemens dishwasher model do you have, exactly?
Sektionschef
Sektionschef
I bought the SX65M042EU. For me, it was a reasonable compromise between price, zeolite drying, and energy consumption. Super fast, super shine, or other fancy features didn’t really interest me – I don’t care whether the machine runs for 3 hours or not. I don’t need to sit next to it, and with our 3 children, running more than one load a day is rare anyway.
@Tuxedo:
Yes, it is a heavy front, but the door does not slam down with force.
I also noticed that before the front was attached to the dishwasher, the door wouldn’t stay down; it would slide back up on its own if you didn’t hold it.
Now it opens easily, stays down, and closes smoothly when you shut it.
Hesse.MTK1 Feb 2015 12:15Hi,
the Siemens SX76P030EU dishwasher (with VARIO hinge) works perfectly with the Ikea Metod 80cm (31.5 inches) front.
You do NOT need adapters like Ikea Vaglig/Behjälplig. The VARIO hinge pushes the front upwards along a guide on the dishwasher door when opening.I would like to purchase according to this solution. Unfortunately, all machines with VARIO hinges come without a cutlery tray.
Does anyone have a model recommendation for me with a cutlery tray? Thanks
IKEA-Experte1 Feb 2015 13:33Siemens SX778D01TE
Bosch SBE88TD01E
Bosch SBE88TD01E
