ᐅ Close the gap to the wall with a panel beside the dishwasher
Created on: 10 Mar 2025 11:43
Jampes74Hello everyone,
I hope I’m in the right place here. I bought a kitchen in modules. The problem is the clear width and the connections.
The clear width is 2.68 m (8 feet 9.5 inches). With the existing connections, I can only arrange the units in the following order (left to right):
Dishwasher 60 cm (24 inches), base cabinet WAAs 50 cm (20 inches), stove 60 cm (24 inches), base cabinet 90 cm (35 inches). The total is 260 cm (8 feet 6.5 inches).
My problem or question is how to best close the gap between the dishwasher and the wall (about 8 cm (3 inches)).
It needs to be fixed in place and covered.
How should I do this so it looks reasonably good?
Thanks for any tips.
Jesse Custer10 Mar 2025 11:50Jampes74 schrieb:
My problem or question is how to best finish the gap between the dishwasher and the wall (about 8cm (3 inches)). It needs to be fixed in place and covered.I don’t understand the need to fix it firmly – it’s a dishwasher, not a washing machine spinning at 1,200 rpm, moving around during operation. Even those aren’t fastened tightly.
Otherwise, since I don’t know the front panel, I can’t comment on color or anything like that – but I would simply anchor a battens to the wall and then screw an 8 cm (3 inches) wide trim piece to the front. Put some TESA Moll (mounting tape) in between and that should do the job.
I’m not aware that a dishwasher needs to be fixed on the side. I would leave the gap and use it for baking trays or cutting boards.
If that doesn’t fit the design, you can have a panel cut to match visually and wedge it between the wall and the dishwasher. If that doesn’t hold, you can also attach it on the side with silicone.
It is also possible to fix brackets to the wall, countertop, or floor, and then glue the panel onto them.
To my knowledge, the open dishwasher is typically secured on the side next to the adjacent cabinet, just before the rubber seal. If it isn't fastened there, it might move when opening or closing, or it could tilt forward when pulling out the rack if it’s not firmly clamped by the countertop.
I’m not sure how it behaves if it’s fixed only on one side. In our last kitchen, a panelled kitchen side was screwed to the outer side of the dishwasher.
Does the countertop overhang, or do you also have the 8cm (3 inches) gap there?
Thanks for your input. By fixing, I meant securing it firmly so the door doesn't move when tilted—not because of the machine itself.
As Musketier mentioned, one side should be attached to the right cabinet. I’m concerned about the other side. I have a faulty door (color: matte anthracite) from which I could cover the gap. But I’m not sure how to secure it properly or how to fix it on the left side with a fastener. I don’t even know if the hinge can be clamped upwards.
The countertop will also overhang.
Explanations aren’t really my thing, sorry. I’ll maybe take a picture later.
You definitely need to fix the countertop separately to the wall, as it should not rest on the dishwasher.
Then, secure it from the remaining front with a wooden batten or similar screwed from the front towards the back.
Possibly on both sides with about 4 cm (1.5 inches) each, so at both ends of the run if it is a 268 cm (106 inch) niche.
