ᐅ Dishwasher front panels
Created on: 26 Mar 2014 11:26
Sektionschef
Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
IKEA-Experte
9 Feb 2015 15:31
And if BEHÄLPLIG ever breaks, will there still be replacement parts available?
V
vienna01
10 Feb 2015 09:17
Regarding the practicality of Behjälplig: I was initially skeptical about whether it would work well, but based on my first impression, this auxiliary hinge seems to fulfill its purpose quite effectively. The dishwasher door stays open at any desired angle, closes almost by itself in the end, and doesn’t look as awkward as I had feared.
How long the plastic parts will last with continuous use remains to be seen – however, I believe that if complaints about worn hinges increase, Ikea will likely produce a version made from aluminum or metal (similar to the guide rails, which are already aluminum) – hopefully.
To prevent the plastic sliders from wearing out too quickly, I will apply some Ballistol (or a similar lubricant) where the sliders move up and down in the guide rail, as well as on the two hinges at the bottom.
As for the additional weight on the dishwasher door: only the weight of the two wooden strips screwed onto the dishwasher door is added – they probably weigh about 1 kilogram (2 pounds) at most. The front door itself does not hang from the dishwasher but is supported by the hinges of Behjälplig!
Sektionschef
10 Feb 2015 09:40
Thanks, vienna01!
Which Bosch model did you actually install?
Regards,
Sektionschef
V
vienna01
10 Feb 2015 11:05
Bosch SBV50M90EU – when searching for my model, I simply checked the built-in installation manual (from the manufacturer!) to ensure it was a model with a height of around 865–925mm (34–36 inches) (correction to my previous post).
In any case, it is not an XXL dishwasher and was therefore more affordable!
Sektionschef
10 Feb 2015 12:38
Thank you!
I just checked, but the SBV50M90EU is an XXL appliance.
The SBE63N20EU should be about the same price and comes with an XXL variable hinge.
Sektionschef
V
vienna01
10 Feb 2015 13:05
Indeed! Sorry, I need to correct myself once again: I installed the Siemens SX65L034EU (which is also a large-capacity dishwasher; the Bosch model number mentioned earlier came from an installation manual on the drive, which I had probably saved as a general template) – but it was still quite affordable! oops:
