ᐅ Floor plan design shortly before submitting the building permit application
Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
As some users have requested before, I’m now starting a new thread with the current planning of our detached house, which is about to be finalized.
These are the preliminary drawings for the building permit / planning permission application, and I have one last chance to review them and point out any issues.
It still seems to me that there is less than 1.20m (4 feet) of space between the two wardrobes in the dressing room. Or am I seeing this wrong? Apparently, the rooms on the left and right were overlooked and not adjusted accordingly.
Two Velux ceiling spotlights are still planned to illuminate the upper floor hallway.
In the basement, on the right side in the upper room, a window similar to the one on the left basement side is an option.
We still haven’t decided on the T30 fire-rated door to the garage, even though it is shown in the plans. Most likely, for safety reasons and the limited use of the kitchen at the other end of the house, we will eventually forgo it.
User 11ant pointed out that the right window in child’s room 2 is suboptimally positioned. However, this could still be changed after submitting the building permit / planning permission application. Our architect thinks moving the window to the left would negatively affect the house’s exterior appearance. We’ll have to see about that.
Grundriss Kellergeschoss mit 3 Kellerräumen, Abstellraum, Flur, Haustechnik und Treppe.
Grundriss eines Hauses mit Keller, Flur KG, Haustechnik KG, Abstellraum KG und Treppen
Grundriss eines Hauses: Garage, Büro, Garderobe, Diele, WC, Küche, Wohn-/Essbereich.
Grundriss Dachgeschoss: Schlafzimmer, Ankleide, Bad, Dusche, zwei Kinderzimmer, Flur HWR Dachterrasse
Technischer Grundriss: Zentraler, ungenutzter DG-Bereich (193 m²) mit umlaufenden Dachschrägen.
Schnitt durch mehrstöckiges Wohnhaus mit Keller, Treppe, Dachkonstruktion und Maßlinien.
Moderne Wohnhausansicht: zweigeschossiges Gebäude mit Garage links und großen Fenstern.
Architektonischer Haus-Elevationsplan: Keller bis Dachgeschoss, Dach, Fenster, Geländeprofil.
Moderne zweigeschossige Hausansicht mit Flachdach, Balkonen, großen Fenstern und Garage.
Zweistöckiges Haus mit dunkler Fassade, grauem Dach, Balkon rechts und Garten mit Bäumen.
11ant6 Jul 2018 21:00
R.Hotzenplotz schrieb:
It may look awkward facing the street if there is an exhaust vent there, but it is definitely better than the pipe.
Oh, come on. A 20cm x 20cm (8in x 8in) grille at lintel height is barely noticeable.
R.Hotzenplotz
7 Jul 2018 08:03
Under what circumstances could such pipes be routed upwards within an exterior wall? This has always been categorically ruled out so far.
Does the energy saving regulation prevent the use of Poroton for pipe installation altogether? We do not have a KfW-certified house. Or are there calculations for this?
R.Hotzenplotz
7 Jul 2018 08:39
What speaks against alternatively draining through the garage? That would be a new approach.
11ant7 Jul 2018 13:25
For something as simple as a soil pipe cut for a toilet, I honestly wouldn’t overcomplicate it by trying to reinvent the wheel.
Just have the pipe bent before it passes through the ceiling and exterior wall, and that’s it. No special treatment, no unnecessary fuss.
R.Hotzenplotz
7 Jul 2018 14:16
Just have the pipe bent before it passes through the ceiling and outside wall, and that’s it. No special treatment, no hassle.
I need to ask again exactly why they didn’t want to do that. They treated the exterior walls like a sacred cow that nobody was allowed to touch. That solution would also be my preferred option.
11ant7 Jul 2018 15:06
You probably remember this from discussions about pipes running through exterior walls. However, this is about a tiny penetration.
