ᐅ Floor plan design shortly before submitting the building permit application
Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
As some users have requested before, I’m now starting a new thread with the current planning of our detached house, which is about to be finalized.
These are the preliminary drawings for the building permit / planning permission application, and I have one last chance to review them and point out any issues.
It still seems to me that there is less than 1.20m (4 feet) of space between the two wardrobes in the dressing room. Or am I seeing this wrong? Apparently, the rooms on the left and right were overlooked and not adjusted accordingly.
Two Velux ceiling spotlights are still planned to illuminate the upper floor hallway.
In the basement, on the right side in the upper room, a window similar to the one on the left basement side is an option.
We still haven’t decided on the T30 fire-rated door to the garage, even though it is shown in the plans. Most likely, for safety reasons and the limited use of the kitchen at the other end of the house, we will eventually forgo it.
User 11ant pointed out that the right window in child’s room 2 is suboptimally positioned. However, this could still be changed after submitting the building permit / planning permission application. Our architect thinks moving the window to the left would negatively affect the house’s exterior appearance. We’ll have to see about that.
Grundriss Kellergeschoss mit 3 Kellerräumen, Abstellraum, Flur, Haustechnik und Treppe.
Grundriss eines Hauses mit Keller, Flur KG, Haustechnik KG, Abstellraum KG und Treppen
Grundriss eines Hauses: Garage, Büro, Garderobe, Diele, WC, Küche, Wohn-/Essbereich.
Grundriss Dachgeschoss: Schlafzimmer, Ankleide, Bad, Dusche, zwei Kinderzimmer, Flur HWR Dachterrasse
Technischer Grundriss: Zentraler, ungenutzter DG-Bereich (193 m²) mit umlaufenden Dachschrägen.
Schnitt durch mehrstöckiges Wohnhaus mit Keller, Treppe, Dachkonstruktion und Maßlinien.
Moderne Wohnhausansicht: zweigeschossiges Gebäude mit Garage links und großen Fenstern.
Architektonischer Haus-Elevationsplan: Keller bis Dachgeschoss, Dach, Fenster, Geländeprofil.
Moderne zweigeschossige Hausansicht mit Flachdach, Balkonen, großen Fenstern und Garage.
Zweistöckiges Haus mit dunkler Fassade, grauem Dach, Balkon rechts und Garten mit Bäumen.
R.Hotzenplotz
5 Jul 2018 14:26
Then I will commission that.
Drywall partition has now also been offered.
Construction work quote: Shower wall will be removed, cost breakdown
Climbee5 Jul 2018 14:49
I really feel sorry for the trouble you're going through, but honestly: who wrote that quote?
Are all the documents prepared that carelessly? Spelling mistakes that make you feel sick? It makes me personally wonder about the general level of diligence in their work...
Especially after all this hassle, I wouldn’t hold back from making a few remarks.
(I admit, I’m fussy about this. To me, it’s also a sign of respect and consideration.)
Otherwise: accept immediately. Position 2 is clearly not priced, and the two guys would be working the extra 7 hours for free. Otherwise, it would cost you an additional €560.
R.Hotzenplotz
5 Jul 2018 14:52
The quote was prepared by the drywall contractor working with the general contractor.
However, the quote appears to be accurate.
What is strange is that after visiting the construction site, he is now mentioning the removal of a shower wall. The shower is located elsewhere and is not affected here at all.
Climbee5 Jul 2018 15:13
Well, as it is written here, it takes two people 7 hours for item 1; at 40€ per person, that makes 40*2*7 = 560€.
The same applies to item 2: also 560€.
That gives me a total of 1120€. Adding material costs of 200€ results in 1320€ net, not 760€ net.
R.Hotzenplotz
5 Jul 2018 15:13
It also says 1,320 € net there.
11ant5 Jul 2018 15:31
Climbee schrieb:
Typos that make you feel sick?
That looks more like "typical builder’s spelling" to me and doesn’t scare me at all. People who really don’t care about spelling tend to make different kinds of mistakes.
In my experience, “dyslexics” are often just people who prefer to focus on the essential things rather than trying to please the language teacher. Half of all bishops can’t pronounce the word “diocese” correctly – but no crucifix has fallen from the wall because of that.
