ᐅ Wall thickness
Created on: 29 May 2014 21:32
freibergerfg
freibergerfg
29 May 2014 21:32
Hello everyone!
We have chosen a Flair 124 ZD from Town & Country. The plan was a 24 cm (9.5 inches) wall made of aerated concrete plan blocks with plaster applied directly onto the blocks. The builder recommends using a 30 cm (12 inches) wall made of the same material instead. Does that make sense, or is it just a way to charge more?
Doc.Schnaggls
30 May 2014 09:38
just to clarify: We are talking about the exterior wall here, right?
Personally, I find a thickness of 24 cm (9.5 inches) a bit thin if no additional insulation is applied.
Is there any energy standard specified for the house?
The concrete builders generally proposed an exterior wall made of aerated concrete with a thickness of 36.5 cm (14 inches).
Dirk
freibergerfg
30 May 2014 11:58
A 24 cm (9.5 inches) exterior wall is probably standard. A 30 cm (12 inches) wall is supposed to improve sound insulation. Nothing is planned regarding the exterior wall for KfW. I am completely overwhelmed.
Doc.Schnaggls
30 May 2014 12:16
Soundproofing is one thing...
In your place, I would also consider thermal insulation.
Is your plot located in a way that soundproofing plays an important role?
Regards,
Dirk
freibergerfg
30 May 2014 12:24
There might be a bypass built in the future. It would then be located about 500 m (550 yards) away.
blockhauspower30 May 2014 12:28
Although I usually don’t rely on them much, if I were you, I would use an online U-value calculator to work out the U-value for your wall.
This will give you an initial reference point. The required U-value for a vertical external wall is currently around 0.24 W/m²·K. However, the energy saving regulations are a mixed calculation, so the U-value of the external wall is only one factor.
Regards
