Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
Sektionschef
robi_aus_ffm22 Sep 2015 20:12hello hinzundkunzbln,
Quote:
Is a continuous baseboard possible with both options?
I have a dishwasher with a flexible hinge and a fully integrated washing machine installed. Their bases are positioned slightly further forward at the bottom. However, this is absolutely no problem. I bought additional METOD legs, cut off the upper plastic knobs on them, and then attached them a few centimeters (inches) further forward, under the cabinets (to the left and right of the appliances as well as the entire front) by screwing into the plastic threaded inserts. The baseboard is then fixed there. This way, you get a straight front even under the cabinet bases by the kickboard.
Regards, robiI don’t quite understand. Does that mean the entire baseboard is positioned further forward under the cabinet, or are the legs mounted further forward than the standard installation position?
robi_aus_ffm22 Sep 2015 20:30Yes, that's what it means. But... as juliette already mentioned, it can also fit perfectly. It depends on the dishwasher and the conditions on site. That's why I only installed the feet further forward afterwards as an additional measure. Regards, robi_aus_ffm
robi_aus_ffm22 Sep 2015 20:38I just reviewed the instructions for the base panels again. The base panel simply clicks into place and that's it.
robi_aus_ffm22 Sep 2015 20:46Exactly, it’s very easy as well. However, it only fits the black Metod plastic feet. The others made of metal (Capita), which are attached with screws, are too thin.
Good evening everyone,
I have a new issue with Metod and a fully integrated Siemens/Bosch dishwasher. I’ve searched the forum for a similar question but couldn’t find anything comparable. Maybe the experts can help.
We want to install the Metod “freestanding” with only a small plinth. The plinth is mounted on the wall at the back, about 10cm (4 inches) high and 20cm (8 inches) deep.
Is it possible to install a dishwasher “freestanding” like this? I understand that the dishwasher needs to be built into some kind of cabinet. I’m mainly asking if something like this would be possible with Metod.
Greetings from Cologne!
robi_aus_ffm23 Sep 2015 08:35Hello habtho,
try searching for modular dishwashers.
