ᐅ What should I do if the IKEA Metod cabinet doors do not align evenly?
Created on: 14 Feb 2019 09:17
LuLaurent
LuLaurent
14 Feb 2019 09:17
Hello everyone, I have a small issue with my IKEA Metod kitchen cabinet doors. During installation, I noticed that the doors on the base cabinets are not aligned flush – there are varying heights and slight offsets between the doors, even though I carefully leveled all the cabinets and installed the fronts correctly. My question is: What can I do if the IKEA Metod doors do not close evenly? Could this be due to the installation, uneven cabinet boxes, or manufacturing tolerances? What steps should I check to ensure all the fronts fit cleanly and flush? I would appreciate your advice, as I want a consistent appearance without any gaps or misalignments.
Sheldon
14 Feb 2019 09:34
First, check all cabinet carcasses for level height and correct alignment. Often, the issue is not with the front but with the carcass itself. Then adjust the door hinges properly so that the fronts close flush.
fugolo
14 Feb 2019 10:04
The issue with Metod doors closing unevenly occurs quite often, usually due to the following reasons:
- Irregularities in the cabinet carcass or mounting surfaces
- Incorrect adjustment of the cup hinges (lateral, vertical, and depth adjustment)
- Variations in material thickness or slightly different front panel dimensions (manufacturing tolerances)
My suggestion:
1. Use a spirit level or plumb line to check that all cabinets are perfectly vertical.
2. Examine the hinge mounting points and adjust them individually. Most IKEA Metod hinges allow three-dimensional fine tuning.
3. Open all doors and compare the gap distances along the edges. Adjust systematically, not just at the most noticeable spot.
If the fronts differ significantly, adding washers at the cabinet fastening points might help.
Hope this helps you with the alignment!
dunitan
14 Feb 2019 11:26
Hello LuLaurent, I’m familiar with this issue from my own kitchen. The key is to stay calm and proceed step by step. First, make sure that all the cabinets are exactly the same height. Even if a cabinet box is just a few millimeters higher, it will significantly affect the fronts.
Next, check the concealed hinges: often, improper tightening of the screws means their adjustment options are not fully utilized.
If you work systematically, you can use the adjustment screws for height, sideways alignment, and depth to get the fronts almost perfectly aligned. Also, make sure the hinges are properly mounted and the screws are not loose.
If there are still misalignments, the cabinet box might be warped; in that case, replacement or repair (e.g., sanding) is usually necessary.
Le-so
14 Feb 2019 12:10
All Metod doors are generally easy to adjust. Take a close look at the hinge settings and compare the height and width of the gaps. If the cabinet frame does not fit properly, using small shims can help to even out the visible alignment.
REOHEINRIC
14 Feb 2019 13:45
Basically, an IKEA Metod front only closes flush if the following conditions are met:
- The cabinet carcass is perfectly plumb and has no distortions
- The hinges are properly and fully installed
- The adjustment screws on the hinges are set so that the door fronts are precisely aligned in height, depth, and horizontally
Manufacturing tolerances are minimal and usually not the cause.
Recommendation: Use a spirit level or plumb line to check the cabinet heights and adjust the doors using the three adjustment screws (side, height, depth). The height adjustment is particularly important for achieving a flush fit.
