ᐅ Ikea Metod: How Can I Attach Doors Quietly and Precisely?
Created on: 10 Dec 2021 09:13
Glachen
Glachen
10 Dec 2021 09:13
Hello everyone, I am currently planning my kitchen using the Ikea Metod system and facing the challenge of mounting the doors so that they are both noise-free and perfectly aligned. Specifically, I am wondering how to best adjust the Metod hinges to ensure the doors fit tightly and close without any noise that might indicate poor alignment or a lack of soft-closing function. What is the recommended procedure during installation to precisely adjust the doors along all three axes, and are there any tips to optimize the performance of the built-in dampers? I have already experimented a bit, but the doors are either too loose or still rattle. I am really looking forward to your advice and experiences!
nofomu
10 Dec 2021 09:42
You should first fully engage the hinges, then adjust the height, depth, and lateral position using the three screws. For silent closing, the damped Metod hinges are sufficient if adjusted correctly.
giabau
10 Dec 2021 10:01
I’m happy to help you with a short guide:
- Step 1: Hang the doors and loosely fix the hinges.
- Step 2: Use the adjustment screws on the hinges to align the door horizontally (side to side).
- Step 3: Adjust the height by slightly loosening the hinges on the cabinet and shifting the door vertically.
- Step 4: Set the depth to precisely control the gap between the door and the cabinet.
- Step 5: Check the door’s fit when closed and readjust if necessary.
Common mistakes include tightening the screws too early, which causes the adjustments to be lost. Also, avoid blocking the dampers when closing.
Summary: Patience is key here, and the small adjustments on the three points will get you to the perfect fit.
Ellis
10 Dec 2021 10:29
Make sure the hinges are installed properly. If the door rattles, it is usually because the screws are not tightened enough or the door is not correctly seated in the track.
RON57
10 Dec 2021 10:55
Hello Glachen, your question is very well posed and addresses a common issue with the Metod series. I would like to provide some additional explanations, as several factors come into play:
- First, it is important to set the cabinet carcass absolutely straight and stable. Even a slight tilt of the carcass causes incorrect door clearances.
- The Metod hinges can be adjusted independently using three screws: height, lateral distance, and depth.
- If you experience noises after installation, be sure to check whether the damping elements on the hinges are correctly positioned and undamaged. Sometimes they are slightly damaged or incorrectly pre-assembled.
- For perfect alignment, it is best to use a small tape measure and initially adjust the doors with minimal spacing to the frame to prevent rubbing.
- Another tip is not to tighten the hinges too firmly until you have completed the final adjustment. This way, you can readjust and avoid tension.
Usually, following this procedure is enough to install doors precisely and quietly.
liRaul49
10 Dec 2021 11:12
Additionally, I recommend lightly treating the door dampers with silicone oil beforehand. This significantly improves the noise levels.
