ᐅ Floor plan design shortly before submitting the building permit application
Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
As some users have requested before, I’m now starting a new thread with the current planning of our detached house, which is about to be finalized.
These are the preliminary drawings for the building permit / planning permission application, and I have one last chance to review them and point out any issues.
It still seems to me that there is less than 1.20m (4 feet) of space between the two wardrobes in the dressing room. Or am I seeing this wrong? Apparently, the rooms on the left and right were overlooked and not adjusted accordingly.
Two Velux ceiling spotlights are still planned to illuminate the upper floor hallway.
In the basement, on the right side in the upper room, a window similar to the one on the left basement side is an option.
We still haven’t decided on the T30 fire-rated door to the garage, even though it is shown in the plans. Most likely, for safety reasons and the limited use of the kitchen at the other end of the house, we will eventually forgo it.
User 11ant pointed out that the right window in child’s room 2 is suboptimally positioned. However, this could still be changed after submitting the building permit / planning permission application. Our architect thinks moving the window to the left would negatively affect the house’s exterior appearance. We’ll have to see about that.
Grundriss Kellergeschoss mit 3 Kellerräumen, Abstellraum, Flur, Haustechnik und Treppe.
Grundriss eines Hauses mit Keller, Flur KG, Haustechnik KG, Abstellraum KG und Treppen
Grundriss eines Hauses: Garage, Büro, Garderobe, Diele, WC, Küche, Wohn-/Essbereich.
Grundriss Dachgeschoss: Schlafzimmer, Ankleide, Bad, Dusche, zwei Kinderzimmer, Flur HWR Dachterrasse
Technischer Grundriss: Zentraler, ungenutzter DG-Bereich (193 m²) mit umlaufenden Dachschrägen.
Schnitt durch mehrstöckiges Wohnhaus mit Keller, Treppe, Dachkonstruktion und Maßlinien.
Moderne Wohnhausansicht: zweigeschossiges Gebäude mit Garage links und großen Fenstern.
Architektonischer Haus-Elevationsplan: Keller bis Dachgeschoss, Dach, Fenster, Geländeprofil.
Moderne zweigeschossige Hausansicht mit Flachdach, Balkonen, großen Fenstern und Garage.
Zweistöckiges Haus mit dunkler Fassade, grauem Dach, Balkon rechts und Garten mit Bäumen.
R.Hotzenplotz
12 Oct 2017 07:58
I'm a bit confused: wasn't this about a guest room? – without natural light / emergency exit? ? ?
You're right. That's probably why they changed the labels from guest room and hobby room to basement room, even though there was a window.
Wasn't something like that required by regulation in the past? In my parents' house from the 1980s, there is a guest room in the basement with a tiny shaft covered by a grate and windows, but you definitely can't get out through it.
Now we're considering what to do.
Maria16
12 Oct 2017 08:14
Just because a room is used as a guest room does not necessarily mean that this use was specified or approved in the building permit / planning permission.
R.Hotzenplotz
12 Oct 2017 08:17
Maria16 schrieb:
Just because a room is used as a guest room doesn’t necessarily mean that this use was stated or approved in the building permit / planning permission.
However, I remember that initially a guest room and a hobby room were declared down there. After preparing the building permit / planning permission application, these terms suddenly disappeared. I was also told something regarding escape routes.
Maria16
12 Oct 2017 08:57
I was referring to your childhood home.
Regarding your building permit / planning permission application: keep asking questions until you fully understand everything.
By now, various contractors might find my numerous questions amusing. But I don’t mind. It’s better to ask too many times than to end up with a result I would have preferred to be different. In your case, however, I sometimes get the impression that you don’t consistently follow through with your questions (for example, now with the room designation) and that you often rely more on others than on yourself. At least during a window-related discussion, I finally thought that you just do whatever 11ant tells you—even though you personally preferred a different option.
R.Hotzenplotz
12 Oct 2017 09:08
Maria16 schrieb:
With you, I sometimes get the impression that you don’t always follow up thoroughly with your questions (for example, now with the room designation) and that you often rely more on others than on yourself.
I have already asked about the room designation. She said it’s no longer allowed to include it like that, but how I use it is my choice.
Maria16 schrieb:
At least during some window discussion, at some point I just thought that you do everything 11ant tells you—even though you yourself preferred something else.
Actually, with the windows, 11ant suggested a different option than the one that will be used now. Otherwise, he came up with very creative and forward-looking ideas. That’s fine.
11ant12 Oct 2017 12:58
Maria16 schrieb:
At least in some window discussion, I eventually just thought you were doing everything 11ant told you to do — even though you personally preferred something else.
Well, hopefully only in one window discussion at most
It would be terrible if someone were to build “my” house here. However, we still disagreed in several areas: I wouldn’t have a garage passage door, no double-width single gate either, and definitely no canopy “beam” built around it.
If you want to find a design that matches my taste as a client, it’s closest to @daniels87’s house in this forum — though I didn’t add much input there, it was already quite advanced when I joined.
