ᐅ Dishwasher front panels
Created on: 26 Mar 2014 11:26
Sektionschef
Hello
Has anyone here already looked into the installation options for dishwasher fronts in the new Metod kitchen system? I have spent some time researching this topic and would like to share my current findings with you:
As I understand it, IKEA now offers the option in Metod to have the dishwasher fronts divided, so they appear as if the dishwasher has multiple drawers. Alternatively, you can install a continuous door as before. This can also be selected in the online planner, which will then display the desired front layout.
Additionally, I found out that Metod requires a special mechanism where the dishwasher fronts slide along rails attached to the dishwasher door. I think it works similarly to the sliding doors on refrigerators.
What isn’t clear to me yet is whether this special sliding mechanism is mandatory with Metod, or if you can still mount the front fixed directly to the dishwasher door as before. Does this have something to do with the different plinth height between Metod and Faktum?
If you want to attach multiple partial fronts to the dishwasher door, you need the Vaglig (20250663) product. This consists of two rails that hold the partial fronts together. But as far as I understand, this does not include the sliding mechanism itself.
For the sliding mechanism, you then need either Resonlig (50248348) or Behjälplig (50242426). The difference between these two seems to be that they fit different dishwasher models (Resonlig for Skinande, Rengöra, and LAGAN; Behjälplig for Hjälpsam). However, I have not yet figured out which one is needed for a non-IKEA dishwasher.
There is also Ersättare (00250664), which appears to be an installation solution for semi-integrated dishwashers. Since IKEA does not offer semi-integrated appliances in their range, Ersättare is probably designed specifically for non-IKEA models that you want to install in Metod. I have also looked at the installation instructions for Ersättare, but some things are still unclear to me:
As I understand it, the lower part of the front must be a partial front with a height of 20cm (8 inches), which is hinged in such a way that it flips open when the dishwasher door is opened. Does this mean that a continuous front is not possible with semi-integrated dishwashers???
Additionally, the instructions state that the upper partial front, also 20cm (8 inches) high, must be cut to size depending on the dishwasher’s trim height. I assume this would only apply to fronts without embossed patterns, because if, for example, I cut a Lidingö front (which has an embossed pattern) in the middle at 20cm (8 inches), I would be cutting through the design?
Since I want to install an existing dishwasher with a semi-integrated front in my new Metod kitchen with Lidingö/Bodbyn fronts, I am currently puzzled about how the installation should actually look.
Since Metod will be available in Austria from April 1st, I will definitely ask IKEA then.
Does anyone already know the answers to my questions?
Sektionschef
IKEA-Experte
13 Nov 2014 15:38
That is probably it, as well as Neff S727P80X0E.
When assembling the front, if it consists of individual parts connected with vaglings, the installation might not go completely smoothly.
lepole
13 Nov 2014 20:18
Is the problem occurring with both machines? What does the "not completely smooth" look like?
Does Vaglig really have to be used there?
tomac72
17 Nov 2014 16:27
I might have a possible solution for semi-integrated dishwashers...
NEFF offers a folding hinge designed for tall cabinet dimensions.
Two silver metal brackets with screws and mounting elements on a white background
I’m not sure to what extent this part can be fitted to other machines, but I think it’s a good alternative to the Ikea ERSÄTTARE solution, which, in my opinion, is not very appealing.
IKEA-Experte
17 Nov 2014 17:07
unfortunately, there are no further details available for the folding hinge. Are there minimum or maximum dimensions for the folding front panel? How is the installation carried out?
The price seems quite high for such simple sheet metal parts.
If anyone has used this hinge, please share your experience.
IKEA-Experte
17 Nov 2014 17:12
Is the problem happening with both machines? What does "not completely smooth" look like?
Is it necessary to use VAGLIG here?
The problem always occurs when the front is mounted directly. The individual parts need to be joined together to form a single front. It is not absolutely necessary to use VAGLIG, but if you don’t, you have to find another way to create the connection. When you screw VAGLIG on, the back of the front is no longer smooth. However, the mounting brackets are designed so that the front rests against the dishwasher door. Therefore, it will be necessary to place something under the brackets with the same thickness as VAGLIG.
tomac72
17 Nov 2014 19:08
unfortunately, there is no further information available about the folding hinge. Are there minimum or maximum dimensions for the folding front? How is the installation carried out?
Try clicking on the dimension drawing or check the additional documentation.
The hinges, which are identical in design (but cheaper), are also available under the item number SZ73010 from Siemens.
