Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Neubau2022
29 Jun 2022 07:59
kbt09 schrieb:
What is supposed to be under that pendant lamp? Or is it just a ceiling-mounted light?
I see both spot placements with the question: "What are they meant to achieve and when should they be on?"
In my living room, I also planned 4 spots as highlights for certain pieces of furniture. These lights are almost always on only briefly when I really need to take something from the cabinet in the dark and can't see it clearly with the general lighting. I could have done without the spots. Translating this to your situation... it would make more sense to have a row of spots along the cabinet side.
On the sofa side... rather wall lamps, floor lamps, etc.
They should be dimmable and provide some light while watching TV. We are not fans of wall lamps. There won’t be anything under the lamp. The dining table will not have a fixed position. When guests come, it will be arranged differently than when it’s just us eating.
The question is valid: why would I need ceiling spots on the cabinet side if there is a 65-inch TV hanging there that provides enough light and a fireplace next to it…
Fuchsbau35
29 Jun 2022 08:27
The recessed ceiling lights at or above the TV can cause glare on the screen when watching, right? So, they might often be turned off anyway.
Also, for recessed lights, you usually need to install a dropped ceiling. I wouldn’t like that, personally (but I'm not really a fan of recessed ceiling lights anyway).
Neubau2022
29 Jun 2022 08:32
Fuchsbau35 schrieb:
The recessed ceiling lights above or near the TV can cause glare on the screen while watching, right? So, they might often not be turned on.
Also, you usually have to lower the ceiling for recessed lights. I wouldn’t like that (but I’m not a fan of recessed ceiling lights anyway).
We don’t need to lower the ceiling in our case. Since we have ventilation ducts in the ceiling, there will already be a 12 cm (5 inch) drywall ceiling installed, which is more than enough for recessed lights without any additional work needed. 😎
Pinkiponk
29 Jun 2022 08:37
Neubau2022 schrieb:
The heating-up phase ended yesterday. The meter shows 6,000 kWh (6,000 kWh). That comes to just under 2,000 €. I had planned for that. Of course, more costs will come from additional work 😎 Finally no more emptying the construction dryer and airing out 2–3 times a day 🙂 But there was an advantage—you had time to inspect the house thoroughly 😎
Is there a noticeable difference between your construction project and ours regarding the screed drying? I ask because of the large differences in construction power consumption. Is it due to the weather, or could there be other reasons? I’d like to understand this better so I can mention this detail when I talk about our construction electricity costs in the future. For screed drying, we used a mobile dryer from our site manager that "somehow" heated the underfloor heating … as I said, using construction electricity.
Mahri2329 Jun 2022 09:14
for example, we have no recessed ceiling lights installed in the living room at all. A pendant light with a large shade is positioned by the sofa and would illuminate the small tables in front of it. It is dimmable and the color can be adjusted. Additionally, there is a dimmable and color-adjustable LED light strip behind the sofa. The TV is indirectly lit from behind by the low cabinet. This can also be dimmed. This creates a very cozy atmosphere and allows the lighting to be adjusted accordingly.
29 Jun 2022 09:37
Neubau2022 schrieb:
The question would rightfully be, why do I need ceiling spotlights on the closet side,
If I were you, I would simply draw in the furniture first. Are ceiling spotlights supposed to improve the sofa area? For the sofa, you might need reading light from a lower lamp. For the TV, it’s advisable to have a light at the TV height, as it is easier on the eyes when watching. Ceiling spotlights are basically not useful for anything except shrinking your wallet and giving you the satisfaction of having cool ceiling spotlights (which aren’t really what you need, just what you want).
