Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Acof1978
7 Aug 2021 19:15
Wiesel29 schrieb:
There must be a reason why almost everyone has the VAT refunded 😉. You also have business expenses that you can claim. Own use can be declared at a flat rate of 20 cents.
If it were a long-term loss for private individuals, it would have been widely known by now, and hardly anyone would register as a business anymore.
And what about the issue of forced hobby activity?
Wiesel29
7 Aug 2021 20:22
Acof1978 schrieb:
And what about the issue of presumed non-commercial activity?
It’s not a problem. You feed electricity into the grid and get compensated for it. So, you have a consistent income stream and thus an intention to generate profits. Overall, your result will be close to break-even or a small taxable loss or gain.
Presumed non-commercial activity typically applies to activities like photography. In that case, equipment worth several thousand euros is purchased and claimed as expenses, but the person never seriously engages in the activity because it’s really just a hobby they try to subsidize.
Acof1978
7 Aug 2021 20:37
Wiesel29 schrieb:
That’s not a problem. You feed electricity into the grid and get compensated for it. So there is a continuous income, which shows an intention to generate earnings. In the end, you break even or have a small tax loss or profit.
A typical example of a hobby activity is something like photography. Equipment worth several thousand euros is purchased and claimed, but you never seriously pursue it as a business because it is really just a hobby you try to subsidize.
Does this mean you have to register a business with the tax authorities before buying the photovoltaic system?
Wiesel29
7 Aug 2021 21:13
Acof1978 schrieb:
Does that mean you have to register a business with the tax office before buying the photovoltaic system?
Yes, you can do that, but you can also register shortly afterwards. It is generally better than submitting everything only with your tax return. This way, the processing usually goes much faster. You should also be aware that in the year you start operating the system and the following year, you must submit monthly VAT returns. After that, due to the amount of income, usually only an annual VAT return is required.
Acof1978
13 Aug 2021 08:49
A question regarding the floor plan. We are considering, if it is still possible, to remove the terrace and instead enlarge the living room. As mentioned, we do not yet know if this will be feasible. This would give us about 11 square meters (118 square feet) of extra space without significant additional costs, since the roof and foundation slab are already planned.
What do you think? Would the building permit / planning permission need to be updated for this? Would a simple amendment be enough, or would we have to start the application process from the beginning?
Grundriss eines Hauses mit Wohnen/Essen, Küche, Bad, Schlafen, Kind 1/2, Terrasse, HWR.
Nida35a13 Aug 2021 11:06
I think it’s good that you are focusing on the floor plan.
The extra space in the living room is a benefit.
So far, nothing has been built; it’s all just on paper.
To find out how the building permit / planning permission is affected, your general contractor or the building authority can inform you.
