Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Nida35a21 Jun 2021 09:55
For us, two people in the bathroom in the morning, of the three main uses—shower, washbasin, toilet—the latter two are too close together. The washbasin should be moved as far left as possible (door swing area + 10cm (4 inches)), and then it would be perfect for us.
Andre77
21 Jun 2021 09:57
@11ant
I think @evelinoz is in Australia... that's why the message is in English with metric measurements.
Acof1978
21 Jun 2021 10:58
Nida35a schrieb:
For us, with two people using the bathroom in the morning, the two fixtures—washbasin and toilet—are too close together out of the three main uses: shower, washbasin, toilet. Moving the washbasin as far left as possible (door swing area plus 10cm (4 inches)) would be perfect for us.
We don’t shower in the mornings, only in the evenings. That’s why the shower and bathtub aren’t used in the morning. In the evening, we’re not in a rush, so we are rarely in the bathroom at the same time. And my grandma always said, "Don’t go to bed dirty." So we shower in the evening :-) You’re right about the washbasin; it will be like that. The cabinet underneath will also be made longer. The bathroom is only just under 10 sqm (108 sq ft).
Nida35a21 Jun 2021 11:01
Acof1978 schrieb:
You are right about the washbasin, it will be like this
30-50cm (12-20 inches) longer on the right side and it will automatically be positioned correctly
pagoni2020
21 Jun 2021 11:04
Having the toilet directly in your direct line of sight upon entering would not be appealing to me, especially right in front of a window. Actually, 10sqm (108 sq ft) is a nice size, but I think you’ll need to rearrange things a bit more. The shower door is cramped and only opens with difficulty; perhaps consider a shower design without a door.
Acof1978
21 Jun 2021 11:26
pagoni2020 schrieb:
Having the toilet directly in the line of sight upon entering wouldn’t appeal to me, especially right in front of a window. Actually, 10 sqm (108 sq ft) is a good size; I think you’ll need to adjust the layout a bit. The shower door is cramped and only opens awkwardly, so maybe consider a shower solution without a door.
It’s a sliding door that moves from right to left (bathtub side). We’re also considering installing a drywall partition next to the door and leaving it open from the bathtub side.
