Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Neubau2022
29 Apr 2022 08:19
OWLer schrieb:
They are the same here as well.
Basically, I would request the heating load calculation "for the records." A target temperature of 35°C (95°F) is really not very ambitious.
It will work, and you can't always optimize everything during construction. That gets tiring.
I have now spoken with the company. Heating load calculations have been and are still being carried out. The numbers stated in the construction specifications are sample figures; installation and settings are based on calculated values.
OWLer29 Apr 2022 08:22
So you can also specify your desired temperatures and the requirement: minimum supply temperature.
The standard version is basically freezing cold.
Neubau2022
29 Apr 2022 08:28
OWLer schrieb:
So you can still specify target temperatures and the requirement: minimum supply temperature.
The standard version is actually freezing cold.
We have already discussed the temperatures for the individual rooms in advance. They will be between 19-21°C (66-70°F).
motorradsilke
29 Apr 2022 08:29
Neubau2022 schrieb:
This is the floor construction. According to the external building supervisors (2 people with a total of over 60 years of experience), everything is perfect.
Just a small tip regarding the floor construction. Pay attention to doors and floor-to-ceiling windows. If they really plan for only a 1 cm (0.4 inch) floor covering and design the doors and floor-to-ceiling windows accordingly, you might not be able to fit any other flooring underneath the doors and windows. In our case, the screed was 2 mm (0.08 inch) too high at the sliding door, which meant I couldn’t install parquet flooring underneath. The fit was also very tight with the interior doors for the parquet. According to the general contractor, I should have made it clear in advance that I wasn’t installing tile flooring.
Neubau2022
29 Apr 2022 08:40
motorradsilke schrieb:
Just a quick tip regarding the floor construction. Pay attention to doors and floor-to-ceiling windows. If you only plan for a 1 cm (0.4 inch) floor covering and design the doors and floor-to-ceiling windows accordingly, you might not be able to install a different flooring under the doors and windows later. In our case, the screed was 2 mm (0.08 inch) too high at the sliding door, so I couldn’t fit any parquet underneath. Even with the interior doors, the parquet fit just barely. The general contractor said I should have mentioned earlier that I wouldn’t be installing tiles.
Thanks for the tip. The floor is also being installed by the general contractor. Except for three rooms (bedroom, children’s room, office), wood-look tiles will be installed everywhere (@11ant’s favorite flooring), and in the other rooms, matching vinyl flooring will be laid. The tiles and vinyl have been ordered and come from the contractor’s supplier. Only the bathroom tiles were ordered externally. However, there are no floor-to-ceiling windows in the bathroom and guest toilet.
motorradsilke
29 Apr 2022 08:45
Neubau2022 schrieb:
Thanks for the tip. The floor will also be installed by the general contractor. Except for three rooms (bedroom, child's room, office), wood-look tiles will be used everywhere (@11ant favorite flooring), and in the remaining rooms, matching vinyl will be installed. The tiles and vinyl have been ordered and come from the GC’s supplier. Only the tiles for the bathroom were ordered externally. However, the bathroom and guest toilet do not have floor-to-ceiling windows.
Then that fits well, and at least you won’t have any problems.
