Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
- Exterior lighting
Neubau2022 schrieb:
We already discussed the temperatures for the individual rooms in advance. They will be around 19-21 degrees Celsius (66-70°F).Bold choice. For me, that would immediately lead to a divorce. For my wife, a living room below 22-23°C (72-73°F) is out of the question. Children’s rooms should also be comfortably warm, and I haven’t even mentioned the bathroom yet.
Neubau202229 Apr 2022 09:33In der Ruine schrieb:
Bold move. In my case, that would immediately lead to a divorce. A living room below 22-23°C (72-73°F) is just not acceptable to my wife.
The children's rooms also need to be comfortably warm, and I haven’t even mentioned the bathroom yet. If necessary, a space heater will be added to the room 😎
Neubau2022 schrieb:
In case of emergency, a space heater will be placed in the room 😎Well, you can also design for a warmer temperature and then throttle back the heating circuit. That would be my recommendation. Everything at 22°C (72°F), bathroom at 24°C (75°F). It can always be colder. It hardly makes any difference for sizing the heat pump.
Neubau202229 Apr 2022 09:47OWLer schrieb:
Well, you can also design for a higher temperature and then throttle the heating circuit. That would be my recommendation. Everything at 22°C (72°F), bathroom at 24°C (75°F).
Colder is always possible. It hardly makes a difference when sizing the heat pump. In our family, we hardly use heating. We prefer fresh air rather than needing it very warm. And as my grandmother always said: "If you’re cold, then put on something warm" 😎
Hausbau 5529 Apr 2022 10:24OWLer schrieb:
They are the same here.
Basically, I would request the heating load calculation “for the documentation.” A target temperature of 35°C (95°F) is really not that high.
It will work, and you can’t always optimize everything during construction. That just gets old. 13 heating circuits for 144 sqm (1,550 sq ft)? I find that too few. We have 13 heating circuits for 90 sqm (970 sq ft). Pay attention to the pipe diameter from the heat pump to the heating circuit manifold. Don’t install any bottlenecks here; use a sufficiently large pipe diameter.
According to some experts, reducing the flow temperature by 1 degree means an efficiency increase of 2.5%. So, lowering the flow temperature from 35°C to 31°C (95°F to 88°F) results in an efficiency gain of 10%. Even an 8% improvement would already be a good result.
You mentioned that the screed will be poured soon. So, the underfloor heating needs to be installed beforehand. For this, the heating engineer requires the heating load calculation to install the underfloor heating! Keep in mind that mistakes in designing the underfloor heating will stay in the house forever. You can always replace your heat pump, but not your underfloor heating.
For the design, we chose 22°C (72°F) in the bathroom and 21°C (70°F) in the other rooms. The pipe spacing is 11 cm (4.3 inches) everywhere, except in the bathroom where it is 5.5 cm (2.2 inches), including under the shower and bathtub.
How much output does your heat pump provide? From my perspective (assuming a correct calculation), 5, maximum 6 kW should be sufficient.
Hausbau 55 schrieb:
13 heating circuits for 144 sqm (1,550 sq ft)? I think that’s too few. We have 13 heating circuits for 90 sqm (970 sq ft). I’d prefer the 144 sqm (1,550 sq ft) as a three-room apartment rather than a bungalow.
By the way: his place is practically finished, so there’s no need to bring up possible/further optimizations.
The next step will be someone asking why not kfw40, then kfw40+, then Passive House…
