Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
- Exterior lighting
Neubau20222 May 2022 17:2311ant schrieb:
More isn’t always better. Try listing everything that’s supposed to be there individually. You wouldn’t have two dozen radiators, for example. On average, that’s one radiator for every 5.5 m (18 feet) squared. I will ask the site manager for the installation plan and then answer the question 😎
Benutzer 10012 May 2022 18:27If each loop is only 50 meters (164 feet) and you calculate with a maximum forward temperature of 30 degrees Celsius (86°F), that is fine. Then, for the bathroom, use a maximum installation spacing of 5-7 cm (2-3 inches) and perhaps a wall heating system. The circulation pump will benefit from this.
I wouldn’t exclude the side-by-side system either; if the settings are different, you can feel a difference of 1-2 degrees Celsius (2-4°F) when walking. I notice it every time I step into the shower.
Neubau20222 May 2022 18:36Offtopic schrieb:
If each loop is only 50 meters (164 feet) with a maximum supply temperature of 30 degrees (86°F), that’s fine. Then keep the bathroom with a maximum pipe spacing of 5–7 cm (2–3 inches) and maybe add a wall heating system. The circulation pump will be happy.
And I wouldn’t exclude the side-by-side layout; if there’s something different there, you can feel a 1–2 degree (2–4°F) difference when walking. I notice it every time I get into the shower. I haven’t dragged that yet. I have applied for the installation plan. Once I have it, I’ll list the key points such as heating loops, their lengths, and spacing in each room. Any other relevant points?
[/QUOTE]
(because here every second new build, house build 1, 22, 55 or whatever is named, it’s hard to keep track... 😀)
Neubau2022 schrieb:That's right, it wasn’t you after all.
Not in my case. Please read carefully 😎
Neubau2022 schrieb:That’s impressive, with just 12 “separate” rooms.
I spoke with the specialist earlier. He showed me the installation plan. 26 heating circuits 😎
Neubau2022 schrieb:Same as in our case. 😉
The company is ATHE-Therm, by the way.
Offtopic schrieb:You can definitely feel that. But the temperature difference is actually much greater.
...when the temperature is set differently, you can feel the 1-2 degree difference when walking around. I notice it every time I go into the shower.
Neubau20222 May 2022 19:03driver55 schrieb:
Right, that wasn’t you after all.
(since here almost every second new build is called Neubau, House Build 1, 22, 55 or something like that, it’s hard to keep track… 😀)
That’s quite a statement, with 12 "separate" rooms.
Just like with us. 😉
You can definitely notice it. However, the temperature difference is significantly higher.
[/QUOTE]
Is it working out well with the company? Have you had good experiences with them?
Neubau20222 May 2022 19:04driver55 schrieb:
Same as with us. 😉Is it any good? What experiences do you have with it?
