Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
- Exterior lighting
Benutzer 10012 May 2022 20:30Neubau2022 schrieb:
Any other relevant points?The supply temperature and the desired room temperature
Mahri23 schrieb:
Hmm... I wouldn’t do it. In my case, the kitchen unit and island were excluded from the underfloor heating, meaning no loops were installed there. And why would that be better? Just because your company implemented it that way?
You have “warm” kitchen cabinets battling mold behind them. I know which option I would choose and which method seems more reliable!
And why would it be better? Because your company implemented it that way?
You have “warm” kitchen cabinets fighting against mold behind the cabinets. I know which option I would prefer, or which method seems more reliable! Because having a couch in front of a wall-mounted radiator, for example, is really inconvenient.
It’s the same principle.
I deliberately didn’t install underfloor heating loops under my kitchen island and L-shaped kitchen.
With 40-50% humidity in winter, there is no significant dew point shift that could cause mold. That is impossible in a new build with current insulation standards.
The efficiency loss is minimal, and with supply temperatures of 28°C (82°F) at -15°C (5°F) outdoor temperature, they are not suitable as plate warmers anyway, so there is no point in installing loops there unnecessarily.
Much more important is designing consistent pipe lengths to the radiators, ideally no more than 80 meters (260 feet).
@Neubau2022 which screed are you getting? Cement or anhydrite?
Anhydrite, or flowing screed, has better thermal conductivity but different disadvantages.
TmMike_2 schrieb:
Because having a couch in front of a wall-mounted radiator, for example, is really problematic.Ah, the apples and oranges argument. So you don’t have any heating under your bedroom bed either? Ten kitchen cabinets cover less area than a double bed… The issue of mold behind kitchen cabinets is quite common. And let’s be honest: which plumber calculates out the saved heating circuits?
Aha! The apples and oranges theory.
So you don’t have heating under your bedroom bed either? Ten kitchen cabinets cover less area than a double bed… The occurrence of mold behind kitchen cabinets is not uncommon. And let’s be honest: which plumber actually deducts the saved heating loops? Thanks for the comparison. I do have heating loops under the bed, but in the end I think it’s a matter of belief.
The €50 (around $55) saved for 50m (164 feet) less piping and the additional planning effort will just balance out.
I just wanted to say that it basically doesn’t matter 😀
In terms of efficiency, leaving out the kitchen heating would be slightly better. Probably saves about €2.5–3 (around $2.75–3.25) per year 😉
Regarding the bedroom: I would set the spacing of the heating loops wider there, unless you want the bedroom temperature to be the same as the living room.
In the bathroom, place them a bit closer together, but this only has a minimal impact (0.5–1°C (0.9–1.8°F)).
It’s important that the shower area also has underfloor heating.
TmMike_2 schrieb:
Regarding the bedroom: I would increase the spacing of the heating loops there, unless you want the same temperature in the bedroom as in the living room.
Make the spacing slightly closer in the bathroom, but that only has a minimal effect.
It is important that the shower area also has underfloor heating. Just to be clear: my house has been standing for 9 years, and I manage my heating loops quite well 😉 ! However, the statement by @Mahri23 seemed a bit questionable to me, so I wanted to ask for clarification!Similar topics
