ᐅ How can I install Ikea Metod kitchen cabinets on an uneven wall?
Created on: 21 Apr 2024 08:07
kegoruHello everyone,
I am currently planning the installation of my new Ikea Metod kitchen and facing a problem: my wall is not completely straight and shows significant unevenness – in some places, there is up to a 2 cm (0.8 inch) difference. My question is: how can I securely and stably attach the Ikea Metod kitchen cabinets to an uneven wall?
I am particularly interested in:
- What methods have proven effective to align the cabinets while still firmly anchoring them?
- Are there specific fastening materials or techniques I should use to compensate for the unevenness?
- Do I need to prepare the wall beforehand (e.g., filling, leveling) or can I work directly with suitable mounting systems?
I want to avoid the cabinets hanging crookedly later or damage caused by poor attachment over time.
Thank you in advance for your tips and experiences!
Hello kegoru,
Thank you for your detailed and precise question; there are quite a few things to consider. I would start with an accurate measurement of the wall, using a spirit level or plumb line to precisely identify any irregularities. This is important before you begin with the installation.
For the actual assembly, I recommend the following approach:
- Check if certain sections of the wall protrude significantly. In these areas, you can attach wooden battens (strips) that you align flush using long screws. These will later serve as support and attachment points for your Metod cabinets.
- If the unevenness varies greatly, it is often advisable to create a substructure using roof battens or tongue-and-groove boards, which are leveled out. The cabinets can then be mounted on this structure.
For the fixing materials, I definitely recommend toggle bolts or similar heavy-duty anchors, which typically hold well on aerated concrete or drywall, if you have such walls.
I would only recommend patching the wall if the unevenness is extreme in one particular spot. Otherwise, it’s better to align and fix the cabinets over the substructure.
Another important point: Check the load-bearing capacity of the wall. Sometimes walls are not designed to hold heavy kitchen cabinets, in which case additional measures, such as installing a special bracket frame, may be necessary.
One more tip: Allow enough time for adjusting and aligning the cabinets, as minor modifications during hanging may be needed due to the unevenness.
Have you already determined how severe the unevenness is at the individual fixing points? If so, I can provide you with more specific advice.
Filippo schrieb:
Have you already determined how uneven the individual mounting points are?Thank you, Filippo, for the detailed response! Yes, I measured with a long spirit level. The unevenness varies between 1 and 2 cm (0.4 and 0.8 inches), mainly in the vertical direction, so the wall curves slightly backward.
It is a solidly built brick wall, which is relatively sturdy.
Your idea of a subframe made from wooden battens sounds interesting. Can I use regular wooden boards for this, or should the battens have specific properties (e.g., treated, certain thickness)?
Also, I would like to know if I can screw the Ikea Metod cabinets directly onto these battens, or if I need additional fastening to the wall itself?
Looking forward to more advice.
Hello kegoru,
For your roughly 1-2 cm (0.4-0.8 inch) uneven brick wall, using a substructure made of wooden battens is a very practical and effective method. Typically, you can use standard pressure-treated roof battens, as these are moisture-resistant due to their treatment and somewhat more durable.
It is sufficient to attach the battens directly to the wall using suitable heavy-duty anchors. You can then screw the cabinets directly onto these battens to create a flat mounting surface. Make sure the substructure is level, for example by using a spirit level when installing the battens, and compensate for smaller irregularities with washers or small wood shavings.
Another option is to use adjustable mounting profiles, which you can screw onto the battens to easily optimize the alignment.
This way, you can use the entire wall as a solid base without having to significantly alter the brick wall itself.
to approach the topic more systematically, here is a brief guide for mounting Metod cabinets on uneven walls:
1. Inspection & Preparation:
- Carefully measure all the fixing points on the wall.
- Note down the distances and irregularities.
2. Creating the substructure:
- Use pressure-treated battens (about 30x40 mm (1.2x1.6 inches)) or timber beams.
- Attach them to the wall using heavy-duty wall anchors (at least 8 mm (0.3 inches) in diameter).
- Level them carefully with a spirit level to create an even surface.
3. Adjustment:
- Use washers or small wooden blocks if needed to compensate for minor gaps.
- Ensure stable connections so the structure will hold over time.
4. Mounting the Metod cabinets:
- Screw the cabinets onto the substructure.
- Use screws of sufficient length to guarantee a secure hold.
5. Final check:
- Verify with a spirit level that the cabinets hang straight.
- Adjust if necessary by tweaking the cabinet feet or readjusting the substructure.
Common mistakes include using wall anchors that are too short or not aligning the substructure precisely. Also, anchoring only into drywall (if present) with simple wall plugs should be avoided, as the load can be too great.
I hope this step-by-step guide helps you!
3. Adjustment:
5. Final check:
