ᐅ How do I assemble IKEA Metod kitchen cabinets with glass sliding doors?
Created on: 19 Oct 2021 08:34
gaufo
gaufo
19 Oct 2021 08:34
Hello everyone, I am currently planning the installation of my new IKEA Metod kitchen cabinets with glass sliding doors and need some assistance. My specific question is: How do I properly assemble IKEA Metod kitchen cabinets with glass sliding doors? In particular, what should I pay attention to when handling the glass sliding doors, which assembly steps are especially important, and how can I avoid common mistakes with alignment and installation? It would be great if you could share your experiences or a step-by-step guide, as I want to avoid any issues with the doors or the stability of the cabinets later on. Thanks in advance!
gesar32
19 Oct 2021 09:12
Hello gaufo, the assembly of IKEA Metod cabinets with glass sliding doors differs from models with regular doors, as special attention must be paid to the sliding tracks and damping systems. It is important to fully and precisely assemble the cabinet carcasses first, following the instructions exactly, aligning the frame and back panel carefully. Then, the sliding tracks are attached inside at the correct positions, both at the top and bottom. The glass sliding doors are only hung into the tracks afterwards, not installed beforehand, to avoid damage to the glass. Be sure to check the cabinets’ horizontal and vertical alignment before hanging the doors, as the problem often lies in the positioning. For the doors themselves: handle the glass sliders carefully, inspect the rubber seals, and after hanging, use the adjustment screws to align the sliding direction. This prevents jamming or tension issues.
giabau
19 Oct 2021 09:48
Hello gaufo, I have put together a short, structured guide to help you assemble the IKEA Metod cabinets with glass sliding doors:
- Step 1: Assemble the cabinet carcass and align it securely; fully install the back panels
- Step 2: Precisely position the upper and lower sliding rails according to the instructions and fasten them with enough screws
- Step 3: Check that the rails are parallel and level (important to avoid running issues)
- Step 4: Carefully unpack the glass sliding doors without applying force
- Step 5: Hang the doors onto the sliding rails – hook the top rail first, then secure the bottom
- Step 6: Check and adjust the door alignment using the screws provided for this purpose on the doors
- Step 7: Final inspection and, if needed, fine-tuning to ensure the doors run smoothly and quietly
Common mistakes include not aligning the sliding rails precisely or hanging the doors in the wrong order. If you manually adjust the doors, do so in small increments. Good luck!
Rodolfo
19 Oct 2021 10:27
I would like to add that special care is required when installing the glass sliding doors. Although the doors are made of tempered glass, the edges are sensitive to impacts. When hanging the doors, you should always have two people to hold them securely and avoid accidental knocks. Another important point is that the running rails must be installed precisely at a right angle to the cabinet. This means you should carefully check with a spirit level and a square before installation. Inaccuracies will cause the door to operate stiffly or sag. It is worthwhile to perform these steps meticulously before hanging the doors.
AUSTINREN
19 Oct 2021 11:05
giabau schrieb:
- Step 3: Check that the rails are parallel and level (important to avoid operational issues)
This is the crucial point. If the running rails are not perfectly aligned parallel, the doors will tilt and become very sensitive to small impacts. One way to check the distance between the rails is by using a string line or a long ruler. Additionally, before finally securing the rails, you should test the sliding direction of the doors several times — this quickly reveals if there is any resistance. Sometimes it is also worthwhile to install the rails with minimal play to allow for fine adjustments later.
Emery
20 Oct 2021 07:21
Just a supplementary tip: When installing the sliding glass doors, pay close attention to the rollers on the doors. If adjusted incorrectly or if the screws are tightened too much, the rollers may distort or get stuck. It is advisable to initially tighten the screws slightly looser, hang the door, and then adjust the rollers or tracks. This way, smooth movement is maintained, and the doors operate cleanly. It is also helpful to check the damping elements at the end of the tracks before closing for the first time to avoid hard impacts.
