Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
- Exterior lighting
Neubau20223 May 2022 16:12TmMike_2 schrieb:
The heating-up program is controlled by the continuous flow heater.
It primarily affects the ceiling; for the floor, it’s too late, and in the ceiling it has many advantages in bungalows.
1. Warm exhaust air rises upwards.
2. Less discomfort from drafts.
3. Less labor required. According to the heating technician, the supply and exhaust air are routed through the ceiling. Everything’s great 😎
Neubau20224 May 2022 09:14The move-in date in July is probably out of the question :-(
Delivery issues with:
- Mechanical ventilation with heat recovery (likely due to the enthalpy heat exchanger)
- Brine-to-water heat pump (I'm still gathering information on this)
- Meter cabinets (currently very difficult to get. Delivery time is apparently around 10-12 weeks...)
We remain hopeful. If we want to cancel by August 31st, we need to do it by the end of the month. We will wait until May 25th to cancel, maybe there will be more clarity by then.
I would consider leaving/allowing an extra month or two before terminating the lease on the apartment. So aim for the end of September/October rather than earlier. Don’t make the timing too tight. You’ll only regret it if something goes wrong. I would talk to the landlord and agree that if you can move in earlier, you will make the shared flat available sooner.
Neubau20224 May 2022 09:35Mahri23 schrieb:
I would consider allowing an extra month or two before terminating the apartment lease. So rather aim for the end of September/October. Don’t make the timing too tight. You’ll regret it if something still goes wrong. I’d talk to the landlord about the possibility of moving out sooner if you can move in earlier.We won’t get that approved. We have a three-month notice period, effective at the end of the month.
Benutzer 10014 May 2022 09:35Please decouple the heat pump from the screed and do not place it directly on it. If it runs continuously 24/7, you might otherwise get a constant humming noise in the screed.
Mahri23 schrieb:
I would probably allow myself an extra month or two before terminating the apartment lease.Exactly, I would only cancel once the general contractor confirms you'll be moving in within 4 weeks.Similar topics
