Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Hausbau 55
31 May 2022 18:51
TmMike_2 schrieb:
I need to ask about that. What materials are your wall and ceiling assemblies made of?
Because when I turn on the fireplace, the temperature rises by 2 degrees and that’s it. Really comfortable in winter. The sand-lime brick walls and concrete ceiling absorb the energy well.
Bungalow, exterior walls 17.5 Poroton with 20 cm (8 inches) insulation, interior walls 11.5 cm (4.5 inches) sand-lime brick.
When I said it got warm, I meant an increase of 2 to 3 degrees. And that with 2 kW.
Neubau2022
31 May 2022 18:56
Hausbau 55 schrieb:
You must be talking about me? How can 2 kW of heating output "blast"? Obviously, you don’t understand how a water-based fireplace works. Out of the 10 kW heating output, the system charged 8 kW into the 1000-liter (265-gallon) buffer storage and only delivered 2 kW to the room.
At least you chose Spartherm, which is a quality manufacturer, but a nominal output of 7 kW would have been clearly too much for ME. You could have made a better decision. Of course, that would have been more expensive.
I mean that you don’t know or didn’t know the difference between a fireplace and a storage fireplace. But the main thing is to complain first...
Hausbau 55
31 May 2022 18:59
Neubau2022 schrieb:
I think you are not familiar with the difference between a fireplace and a storage fireplace. But first of all, complaining...
Now I would like to hear your explanation.
Even if you accuse me of ignorance... I was proactive enough to install a better system.
Neubau2022
31 May 2022 19:00
Even if you accuse me of ignorance... I was forward-thinking enough to install the better system.
Alright. Then you did everything correctly and can continue trolling in your thread...
Hausbau 55
31 May 2022 19:04
Neubau2022 schrieb:
Good. Then you did everything right and can continue posting in your thread...
Please explain to us the difference between a fireplace and your masonry heater.
TmMike_2
31 May 2022 19:04
Hausbau 55 schrieb:
Bungalow, exterior walls 17.5 Poroton with 20 cm (8 inches) external thermal insulation composite system (ETICS), interior walls 11.5 cm (4.5 inches) calcium silicate bricks.
When I said it got warmer, I meant an increase of 2 to 3 degrees. And that with 2 kW.
Understood. The drywall ceiling, for example, hardly absorbs any heat.
Thank you. My wood stove produces 4.5 kW over 8 hours.
That means I put in about 10–11 kg (22–24 lbs) of wood at once, let it burn for 2–3 hours, and the rest of the heat is gradually released.
