Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
- Exterior lighting
Neubau202231 May 2022 19:13Hausbau 55 schrieb:
Please explain to us the difference between a chimney and your heat-retaining fireplace. If you read carefully, you wouldn’t have needed to ask that question. As I already said, it doesn’t make sense to only read what you want to. If you still want an explanation, ask Uncle Google.
Hausbau 5531 May 2022 19:13TmMike_2 schrieb:
Alright. For example, the drywall ceiling hardly absorbs any heat.
Thanks. My masonry heater has 4.5 kW over 8 hours.
That means I put in 10.11 kg (22.3 lbs) of wood once, let it burn for 2–3 hours, and the rest of the heat is gradually released. Neubau2022 has the same construction method as we did back then, also a drywall ceiling. And a masonry heater is definitely a different concept. I’m not familiar with that.
Neubau2022 has two large glass fronts. If he puts in 3 to 4 logs and lets them burn properly, the heat escapes through these large glass fronts—it’s radiant heat into the room. In this case, potential thermal mass materials used when building or cladding the fireplace are not particularly important.
Neubau202231 May 2022 19:20Hausbau 55 schrieb:
Neubau2022 has the same construction method as we did back then, also a drywall ceiling. And a masonry heater operates on a different principle, which I’m not familiar with.
Neubau2022 has 2 large glass facades. If they place 3 to 4 logs in the stove and burn them properly, heat will escape through these large glass surfaces, since it’s about radiant heat into the room. In this case, potential thermal storage materials used when enclosing or cladding the fireplace are not particularly relevant. OK. You are right, and I will keep quiet...
Neubau2022 schrieb:
OK. You’re right, and I’ll keep quiet... I would call it experience.
You always have those 500 degrees (assumed; definitely very hot 😀) on the glass, no matter how you “wrap” the insert with the stones.
Hausbau 55 schrieb:
...I was proactive in installing the better system. Just out of curiosity, may I ask what about @Neubau2022’s decision triggered you so much that it led to three pages of discussion?
Hausbau 5531 May 2022 20:06Yaso2.0 schrieb:
Just out of curiosity, may I ask what about @Neubau2022’s decision triggers you so much that it has generated 3 pages of text already?Other homeowners should avoid making such impractical decisions regarding the fireplace. Is my brief answer sufficient for you?
