ᐅ How can I effectively clean IKEA Metod glass fronts?
Created on: 18 May 2016 08:32
Min38
Hello everyone, I’m here because I have a specific question about cleaning the glass fronts of IKEA Metod kitchens. These glass fronts tend to look a bit dull after some time, and I feel that regular glass cleaners are okay but don’t seem to leave the desired long-lasting shine. Maybe this is due to coatings or special materials IKEA uses. So my question is: How can I effectively clean IKEA Metod glass fronts so they stay streak-free, glossy, and as scratch-free as possible? Are there any special cleaning agents, home remedies, or techniques that have proven to be particularly helpful? I would appreciate detailed tips, especially regarding the compatibility of cleaning products or gentle methods. Thanks in advance!
Min38
18 May 2016 14:47
Thank you for your tips so far! The idea of using vinegar in the water sounds interesting, but I have concerns that the vinegar might leave odors or possibly damage the seals or frames. Does anyone have experience or insights on this?
Ixvin schrieb:
If you want to be sure not to damage the glass fronts, you should keep the cleaning as gentle as possible.
That is very important to me as well, since I have already seen how improper cleaning can quickly worsen the appearance of other furniture surfaces.
I’m also wondering if a dedicated glass cleaner is better than, for example, mild all-purpose cleaners that I often already have at home? Or would that carry risks? I definitely want to avoid any long-term residues or dull surfaces.
DUKUSU
18 May 2016 15:13
Hi Min38, the vinegar smell disappears quickly, no worries! 😊 I’ve often used vinegar water to clean glass surfaces, and it leaves them really clean and streak-free. If you’re concerned about seals, you can lightly dampen the microfiber cloth instead of spraying directly.
By the way, if you occasionally wipe the glass surfaces dry in between, they’ll stay cleaner and shinier for longer. Just be careful that no coarse particles dirty the cloth, as that can cause scratches!
I also sometimes use a mixture of dish soap and vinegar. It works really well on greasy stains. Just make sure to wipe it off thoroughly!
CHRISTOP33
19 May 2016 09:37
Hey everyone! 😊
Let me lighten the mood a bit: I just mixed a small splash of denatured alcohol in water, then cleaned the IKEA glass fronts with a soft cloth. The result? Crystal-clear shine with no streaks, and during your next visit, you can even see your selfies reflected. 😉
But: Always wipe dry thoroughly and don’t soak the surfaces! And avoid aggressive scrubbing – the glass fronts are as delicate as a kitten. 😉
Give it a try!
maureo
19 May 2016 10:11
For me, plain clean water and a microfiber cloth are sufficient. For heavier dirt, use dish soap, but make sure to wipe again thoroughly with clean water afterwards. Avoid aggressive cleaners or abrasive agents!
Santiagobu
20 May 2016 07:54
Min38 schrieb:
The idea of using vinegar in water sounds interesting, but I’m concerned that the vinegar might leave odors or possibly damage the seals or frames.
Hello Min38,
Vinegar is quite effective at removing limescale stains, and the smell usually dissipates quickly in open air. However, you should be cautious with plastic seals or metal frames, as acetic acid can damage some materials over time.
My advice is to first test the vinegar solution on an inconspicuous area and use it only diluted (for example, 1 part vinegar to 10 parts water). Alternatively, mild dish soap also works well for cleaning without the potential risks.
Regarding glass cleaners: avoid products containing ammonia, as they can damage glass surfaces. The gentlest method remains cleaning with warm water, mild dish soap, and a soft microfiber cloth.
If you like, I can provide you with a precise mixing ratio.
Annedeo
20 May 2016 08:28
CHRISTOP33 schrieb:
I’ll add a bit of lightness: I just mixed a small splash of denatured alcohol in water, then cleaned the IKEA glass fronts with a soft cloth.
That sounds like a good alternative! Denatured alcohol also has degreasing properties and dries quickly. However, I would still advise caution when using it, especially on delicate seals and coated glass surfaces. It’s always important to only slightly dampen the cloth and then wipe dry thoroughly.
Since you put it in a casual tone: yes, sometimes the glass fronts really are as delicate as a kitten – gentle care is the only way!
